63 rear brake drum part # - NCRS Discussion Boards
  • Todd L.
    • November 25, 2020
    • 298
    Can anyone tell me what the part # is for 63 rear brake drums? I have looked everywhere trying to find a part #, even the 63 assembly instructions manual, and all it calls out is "brake drums". I have a few drums here and need to figure out which ones are correct for this car. Thanks so much!
    Todd
  • Harry S.
    • July 31, 2002
    • 5335
    Re: 63 rear brake drum part #
    Have a read -----> https://www.forums.ncrs.org/showthre...hlight=3828688
    I just looked at one, the casting number is 3828688, with a W6
    • Todd L.
      • November 25, 2020
      • 298
      Outstanding! Thanks for the information Harry, I have copied into my notes, the info for the part #'s from the post you referenced. I appreciate the detail!
      Todd
        • 15706
        What you see embedded in the drum is the casting number. There were two finished part numbers, one for base brakes and one for J-65 that had a finer finish on the friction surface.
        Over the years casting numbers changed, like when the max. diameter was embedded in later service castings, but basically most 11 x 2" Chevy drums will work on the rear of a C2 drum brake car, and front or rear on a C1 for that manner.
        List all the casting numbers and sizes you have and we might be able to figure them all out.
        • Todd L.
          • November 25, 2020
          • 298
          Thanks for the detail Duke,
          The other part # I have is GM 3762628 36
