Can someone please show me pix of the rivets of rear (#4) body mount reinforcements? - NCRS Discussion Boards
  • Brian E.
    • May 28, 2018
    • 287
    info@tacticallink.com
    Thanks in advance.
    Brian
  • Leif A.
    • August 31, 1997
    • 3650
    Re: Can someone please show me pix of the rivets of rear (#4) body mount reinforcemen
    Brian,
    Picture of my #4. Hope this helps. First pic driver's side, second pic passenger side.
    Leif
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11360
      Here are a few from a '67 convertible I did over. I've done quite a few over the years.
      This is the #4 mount. Note that the nutplate for the square nut must be installed before the actual body mount is installed.
      It's quite cumbersome to get in there and have someone use a backer on the heads while the rivet gun hits them in the wheel well. The rivets are 3/16" diameter aluminum with a large flat head to sit in the recesses of the fiberglass.
      Before
      After
      Rich
      • Leif A.
        • August 31, 1997
        • 3650
        Rich,
        In your picture, there is a weld nut on the mounting bracket. Is there a difference between coupe and convertible? What is secured by the weld nut on the convertible bracket? Thanks.
        Leif
        • Brian E.
          • May 28, 2018
          • 287
          Originally posted by Leif Anderson (29632)
          Rich,
          I was wondering the same thing Leif.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11360
            That's for the deck lid hinge tower. 2 cars shown....
            • Leif A.
              • August 31, 1997
              • 3650
              Thanks Rich. Hope Brian got all the info he needed.
              Leif
              • Brian E.
                • May 28, 2018
                • 287
                Thanks Rich and thanks Leif. I appreciate the photos you've shared with me. Thanks again.
                • Brian E.
                  • May 28, 2018
                  • 287
                  Today I removed all the rivets that were not correctly installed. I will be obtaining the necessary tooling, supplies and materials needed to properly install these rivets. Thanks again to all who helped.
