1968 tilt wheel - NCRS Discussion Boards
1968 tilt wheel
  • Jerry C.
    • November 1, 1995
    • 741
    1968 tilt wheel
    Have a buddy looking for a 68 tilt steering column. Anyone know where I might find one? Thanks in advance
  • Daniel S.
    • February 1, 2000
    • 164
    Re: 1968 tilt wheel
    Believe 68 only offered the N36 telescopic steering wheel. There are aftermarket options available that will work. It is also possible that the 1969 and up Corvette tilt/tele option from GM may work.
    • Tom B.
      • March 1, 2002
      • 140
      Re: 1968 tilt wheel
      No tilt on 68 telescopic only 69 tilt tele will fit but has a ign lock on the column where 68 is on dash. Probably aftermarket columns out there.
      • David M.
        • September 30, 2004
        • 533
        Re: 1968 tilt wheel
        Correct no tilt offered in 68.
        Our only option was an Ididit column.
        I just installed one in our 68, Went in nice. Electrical was a breeze.
        Minor issue with the rag joint You have to grind off the original studs to install the new joint. New joint kit and firewall seal were from Corvette Central.
        Couldnt reuse the OEM screws that mount the steering wheel and horn ring to the new billet hub as the hub threads were a different pitch thread. Found Stainless hex heads at HD to solve that problem.
        The OEM horn contact leg was not long enough. I simply used the red wire in the column as it came with a solderless female spade terminal. I pushed the terminal on to the L shaped end of the OEM flat brass leg and tucked the wire out of the way. Its actually a clean job.
        I tried to add pics but as soon as I hit upload it disappears?
