Rear Holley Carb bowl leak from bottom pressed in plug - NCRS Discussion Boards
  • Robert W.
    • June 28, 2018
    • 134
    Hi, The leak I had thought was from vent hose blow-by now looks like its from a small leak in the rear (bottom) carburetor bowl plug. The bowl to carb body seal is "dry." Any ideas as to how to seal this after I disassemble and clean/flush out any gas residue? I'm wondering if a few drops of Loctite 545 will seal it up...
  • Stephen L.
    • May 31, 1984
    • 3157
    Re: Rear Holley Carb bowl leak from bottom pressed in plug
    You might try some JB Weld..... possibly on the inside of the bowl. Make sure the residue is gone in the area. Use some alcohol or suitable cleaning agent that will evaporate.
    Let it cure for 24 hrs. Whatever you use must be fuel resistant.
    • Ed S.
      • August 6, 2014
      • 1377
      JB Weld definitely works. I successfully sealed the back side of the pressed in plug in my Holley secondary bowl. JB Weld is resilient - does not degrade when exposed to gasoline.
      Ed
      • Michael H.
        • December 1, 1987
        • 729
        I have had good luck with Seal-All on my plugs.
        • James W.
          • December 1, 1990
          • 2655
