best epoxy - NCRS Discussion Boards
best epoxy
  • Bruce W.
    • June 30, 1997
    • 360
    best epoxy
    Hey Guys,
    I have been doing some research on epoxy. Seems that JB weld is most used? Recently heard about Duracraft,
    all craft professional ET40 epoxy. Has anyone had any experience with this product? Would appreciate your help.
    Bruce
  • Jim L.
    • September 30, 1979
    • 1816
    Re: best epoxy
    Bruce,
    I've used JB Weld for lots of purposes and haven't had an issue with it. I haven't heard of the Duracraft product. What are you needing to do?
    Jim
    • Bruce W.
      • June 30, 1997
      • 360
      Re: best epoxy
      Jim, still contemplating a fix for the stripped bolt hole on a head for a valve cover. Tried filling drilling and tapping using JB weld but it didn't hold. I heard this product to be even stronger. supposed to be great for steel?
      Bruce
      • Daniel T.
        • July 5, 2019
        • 34
        Re: best epoxy
        For the thread repair, loctite makes a product specifically for that, cleanliness is key to success. I'd also try to get a few threads deeper in the hole with a bottoming tap so then you are holding on some threads in steel and some in the loctite product (2 part epoxy).
        62 Corvette 327/340
        63 Corvette SWC 327/300
        67 Corvette Convertible L79
        2006 Corvette Z06
        2011 Corvette Grand Sport Convertible
        also a couple 68 Camaro's
        • Bruce W.
          • June 30, 1997
          • 360
          Re: best epoxy
          Daniel, will check that out but this has already been drilled to get out broken bolt. I am not comfortable with drilling deeper. Don't have the experience. Thanks for your input.
          Bruce
          • Jim L.
            • 1816
            Re: best epoxy
            Bruce
            Isn't there enough metal around the hole that you could install a Heli-coil? That's what I would try.
            • David G.
              • May 31, 1980
              • 275
              Re: best epoxy
              I agree. A heli-coil is the most permanent way to repair this.
              • Bruce W.
                • June 30, 1997
                • 360
                Re: best epoxy
                Jim, not enough meat around the hole for Heli -coil. Trying to avoid pulling the head. already tried JB. Didn't hold. Am going to try Duracraft Professional et-40 heard good things but I am trying to find out if it is stronger than JB weld. do you have any experience with this product?
                Bruce
                  • April 1, 2000
                  • 477
                  Re: best epoxy
                  I've had good luck with time-sert (or big-sert) inserts in cases where there wasn't enough material for a heli-coil. I have actually have used time-serts in this very application with success. They can be pricey, especially in larger sizes, but in this smaller size they are cheap enough IMHO.
                  • Dennis C.
                    • June 30, 2002
                    • 884
                    Re: best epoxy
                    Bruce
                    Bruce, I also have used JB Weld with good success. A couple of things, you need to use the standard JB Weld and not the quick setting. You also need to wait a minimum of 24 hours for it to cure.
                    • Michael M.
                      • February 1, 1993
                      • 604
                      Re: best epoxy
                      Marine Tex is a great product available at Marine supply stores.
                        • 11678
                        Re: best epoxy
                        Devcon 10110
                        • Bruce W.
                          • June 30, 1997
                          • 360
                          Re: best epoxy
                          Dennis, thanks for the input. tried JB weld let it set, Didn't hold up. do you know about Duracraft All craft Epoxy Et-40? suppose to be stronger?
                          Bruce
                          • David H.
                            • June 30, 2001
                            • 1545
                            Re: best epoxy
                            Hey Guys,
                            Bruce
                            Bruce
                            Instead of JB Weld on a bolt, try using a stud. JB Weld an ALLEN HEAD stud of appropriate length into that head. Use a nut/washer on that stud to secure your valve cover. Allen head stud will allow you to minimize stud twist in the head - tension only no twist. See image below.
                            Dave
                            edit sorry can't get image to load. Try this link:
                            Bel-Metric sells metric hardware & specialty automotive supplies worldwide. Visit our website to purchase metric fasteners, nuts, bolts, screws, washers & more.
                            • Dennis C.
                              • June 30, 2002
                              • 884
                              Re: best epoxy
                              Bruce
                              No Bruce, I do not. As I indicated, I have never had an issue filling a damaged hole with JB Weld and redrilling and threading it after it was cured.
