C2 shifter boot - NCRS Discussion Boards
C2 shifter boot
  • John P.
    • August 31, 2002
    • 218
    C2 shifter boot
    Trying to replace a torn boot on my 65 convertible. Just wondering what is the best way? AIM doesn't show details.
    Is it intended to be slipped over the shifter knob?
  • Tom B.
    • March 1, 2002
    • 140
    Re: C2 shifter boot
    No unscrew the shifter knob and pull out the reverse T handle then slip the boot on and reverse assemble the parts.
    • John P.
      • August 31, 2002
      • 218
      Re: C2 shifter boot
      Was wondering about that. The knob will not budge. Any ideas on loosening it without scarring it up?
      • John P.
        • August 31, 2002
        • 218
        Re: C2 shifter boot
        Is there a lock nut under the ball?
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11334
          Re: C2 shifter boot
          No nut typically John. Try one of those rubbery jar openers.
          But you'll have to remove the shifter console. There are(iirc) 11 screws holding the boot reinforcement into the underneath nut plate. Hope not too rusty.
          Rich
          edit... found some photos...
          P8100031.jpgP8100006.jpgP8100007.jpgP8100011.jpgP8100010.jpgP8100029.jpgP8100030.jpgP8100036.jpg
          • John P.
            • August 31, 2002
            • 218
            Re: C2 shifter boot
            Thanks Richard.
            My problem now is that I cannot remove the ball-it is marred from my efforts.
            I cannot tell from the AIM how to most easily remove the entire shifter from below.
            I am going to try a heat gun but have this feeling that the whole shifter will need to go to a machine shop
            Thank for any further suggestions
            • Gary J.
              • April 1, 1980
              • 1244
              Re: C2 shifter boot
              If you are planning on having the car judged you need to source an NOS one. The repros are different.
              • Gary B.
                • February 1, 1997
                • 7052
                Re: C2 shifter boot
                Gary,
                For the shifter? Or the ball? What exactly is different for a repro from the GM original?
                Gary
                • Gary J.
                  • April 1, 1980
                  • 1244
                  Re: C2 shifter boot
                  The rubber boot is thicker than the original. Also there is a configuration difference where shifter comes through the hole. The ring is different.
                  • Gary B.
                    • February 1, 1997
                    • 7052
                    • Gary J.
                      • April 1, 1980
                      • 1244
                      Re: C2 shifter boot
                      Gary,
                      I don’t know anything about the shifter ball. What I am referencing to is the rubber shifter boot. I do agree with you as once the shifter ball is mounted it would be hard to determine the weight of the original and the repro.
                      • John P.
                        • August 31, 2002
                        • 218
                        Re: C2 shifter boot
                        Any suggestions on removing the ball?
                        • Frank D.
                          • December 27, 2007
                          • 2703
                          Re: C2 shifter boot
                          I have a cylindrical, plastic housing for a filter on my pump that I use to irrigate from my lake - about 1-1/2" around that I must clean weekly; I swear that housing arc-welds istelf at the threads. I use something like this to wring it loose - don't know if Harbor Freight would have one small enough. Clean the ball thoroughly with alcohol and let dry before attempting:
                          • Mark F.
                            • July 31, 1998
                            • 1569
                            Re: C2 shifter boot
                            The tool Frank shows looks nice (I might have to get one )
                            Also, I have seen plumbers use an old leather belt wrapped around chromed piping so it won't get marred - and then carefully use a pipe wrench to tighten or loosen.
                            I know it sounds horrific, but it worked the times I've seen it done...
                            thx,
                            Mark
                            • Frank D.
                              • December 27, 2007
                              • 2703
                              Re: C2 shifter boot
                              Also, I have never removed a T handle to install a boot on a C1 or C2; I stretch the hole over one arm of the T CAREFULLY and then pull it in the other direction over the second arm, never had a new boot tear doing so. I usually douse the boot with silicone spray first.
                              Not saying anybody should do this unless they want to risk damabe, but I have at least 4 times without issue.
