Emblem removal - NCRS Discussion Boards
Emblem removal
  • Perry M.
    • January 1, 1977
    • 325
    Emblem removal
    Does anyone have a suggestion how to safely remove the gas door emblem on my '84 so I can clean and polish the area around it? I removed the two acorn nuts from behind but the emblem is stuck on with what appears to be foam tape. I don't want to damage the paint or emblem.
  • Michael H.
    • December 1, 1987
    • 726
    Re: Emblem removal
    Use fishing line under the emblem, do it slowly.
    • Thomas N.
      • July 31, 2002
      • 397
      Re: Emblem removal
      And soak the double sided tape residual on the door with goo gone.
      NCRS New England Chapter Chairman 2022, 2024
      N E Regional Chairman 2024
      1967 Corvette Convertible Under Restoration
      1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
        • 15596
        Re: Emblem removal
        Dental floss will also work. "Saw" back and forth under the emblem. Slowly as suggested by Mike H.
        • Perry M.
          • January 1, 1977
          • 325
          Re: Emblem removal
          Yes, I have performed this fishing line/dental floss removal in the past but I was hoping to reinstall the emblem after cleaning and polishing. Will I still be able to reuse the emblem with damaged tape?
