C2 or C3 Engine Failure on the Assembly Line? - NCRS Discussion Boards
  • Owen L.
    • September 30, 1991
    • 891
    What were the common steps that the Corvette assembly line would have followed if an installed engine had a full blown failure that required a replacement block?
    Would the replacement block have been stamped just like the original such that there would be no indication it was not the first engine installed?
    Were CE engines only installed after a car left St. Louis?
  • David H.
    • June 30, 2001
    • 1559
    Re: C2 or C3 Engine Failure on the Assembly Line?
    Owen
    Expect this was a very rare occurrence as engines got a "hot test" before being shipped from Flint.
    John Hinckley published an interesting Flint Engine Manufacture article. Available at Camaro.org, link below.
    That said, seems like they had plenty of engines on-hand at St Louis.
    Dave
    Judging Chairman Mid-Way USA (Kansas) Chapter
    • Mark F.
      • July 31, 1998
      • 1595
      Originally posted by David Houlihan (36425)
      ...John Hinckley published an interesting Flint Engine Manufacture article. Available at Camaro.org, link below. That said, seems like they had plenty of engines on-hand at St Louis. http://www.camaros.org/flintV8.shtml Dave
      Excellent and interesting link, Dave. Thanks!
      At the end of the first link you provided, JH says, "Now that we have the engine built, tested (sic started and hot-tested for the first time), painted, and shipped, we'll follow it down the Engine Dress Line in another article - Engine Dress Line."
      At the end of Engine Dress Line article, JH says, "If an engine was found to be defective when the car was started (sic for the second time in the assembly plant) at the end of the line or during Roll Test, that engine was removed and returned to Flint or Tonawanda for credit, and a new engine was dressed for that car and installed in Final Repair. Major internal engine repairs weren't done in assembly plants - they were neither equipped nor trained for that kind of work."
      thx,
      Mark
      • James G.
        • August 22, 2018
        • 808
        Really good information over there they have a pretty good handle on assembly practices - John wrote a long paper on Camaro Assembly process from sheet metal stampings coming into Fisher Body to cars rolling off the Chevrolet assembly line - he was involved quite heavily until he was over to the Lordstown plant for it's reconfiguration from Firebird to Vega production in March-April 1969.
