69 Strut arm cam bolt - NCRS Discussion Boards
  • Mark S.
    • April 25, 2019
    • 94
    On the strut arm adjusting cam bolt assembly there is a hole across from the bolt where the degree marks are. Does it matter weather the hole faces in or to the wheel side? I have seen pictures both ways. I would think they should both face the same direction but as long as the alignment is correct does it really matter. Can't see anything about this in the JG.
    Mark
    • 6958
    Re: 69 Strut arm cam bolt
    Mark I put my Cam bolt with hole facing the top. Not sure that it really matters, as you say it will end up the same once aligned. The main thing is the cam bolt head should be facing then the front of car.
    • Mark F.
      • July 31, 1998
      • 1605
      this is what mine looked like when I pulled it out for rear end rebuild...(2004)
      thx,
      Mark
      • Mark S.
        • April 25, 2019
        • 94
        Thanks. Appreciate the feedback...
