1975 water neck bolt same as 73-4??? - NCRS Discussion Boards
  • Bob B.
    • January 31, 2007
    • 524
    Yes, I snapped the head off the long bolt holding the water neck connecting top radiator hose to the intake manifold- my bad.
    Paragon has a repro bolt kit for 73/74 but says the 1975 bolts may be different-
    Does anybody have any idea if the bolts are the same 75 as earlier is the 75 bolts available ?
    Bob
    #967
  • Tom R.
    • June 30, 1993
    • 4100
    Re: 1975 water neck bolt same as 73-4???
    If you're talking thermostat housing, we found a lot of carryover and not much clarity on the use of thermo housings throughout this period. I take it you have the 3rd edition of the 73/74 but have attached the pages of same for the 3rd edition of 75-77. Those bolts may be based on the housing used for your particular application.
    Hope this helps.
    1975-77 _thermostat housing_30Sep21.pdf
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
