1972 replacement headlight - NCRS Discussion Boards
  • Fred H.
    • December 4, 2019
    • 314
    Understanding that finding period correct OEM replacement headlights for our 72 are few and far between. What would be a replacement lamp that will receive this fewest originality deduct points?
    Fred Hickey
    Fred Hickey
    Care taker of Top Flight 72 LT1 C60 Convertible #26756
  • Leif A.
    • August 31, 1997
    • 3648
    Re: 1972 replacement headlight
    Fred,
    When I get home later this afternoon/evening, I'll check my stash. I think I may have a set of four that are correct for your '72. They were on my '67 when I bought it years ago (and functioning fine). I replaced them with a correct set for my model year. If I remember correctly, they are non-DOT, as well.
    Leif
    • Fred H.
      • December 4, 2019
      • 314
      Leif, that would be great. My son and I just finished a body off restoration on our #'s matching 72 LT1 convertible ac car. We're entered in the SoCal chapter judging event (10/15/21) and trying to fine tune what we can before. Fred
      Fred Hickey
      • Leif A.
        • August 31, 1997
        • 3648
        Fred,
        I checked the four bulbs that I have (two low beam, two high beam) and I believe they're for a '68-'71 model. Picture below.
        Note: No DOT marking
        Leif
        • Fred H.
          • December 4, 2019
          • 314
          Hi Leif, would you consider selling those?
          Fred Hickey
          • Leif A.
            • August 31, 1997
            • 3648
            Absolutely. I'll send you a private PM with info.
            Leif
            • Don L.
              • August 31, 2005
              • 1005
              Don Lowe
              NCRS #44382
              Carolinas Chapter
              • Fred H.
                • December 4, 2019
                • 314
                Hi Don, Thanks for your reply. I believe I saw an earlier discussion with you participated in regarding OEM correct 72 headlights. I have received some leads on correct lamps for our 72 LT1.
                Fred Hickey
                  • 15626
                  These are also referred to as "Power Beam" lamps. See that designation around the bottom of the bulb in Don's image.
                  • Don L.
                    • August 31, 2005
                    • 1005
                    Actually, Terry, the bulb pictured in my posted photo says SEALED BEAM. As I shared earlier, I think the POWER BEAM began in 1973 (?)
                    Don Lowe
                    NCRS #44382
                    Carolinas Chapter
                      • 15626
                      Right you are Don. It was right in front of me and I read something else.
