69 radio wiring - NCRS Discussion Boards
69 radio wiring
  • Mark G.
    • January 31, 2007
    • 177
    69 radio wiring
    I have no power on the yellow wire that plugs into the left side of the radio. Does it just go to the radio fuse in the fuse block or is there a connector/splice between the fuse block and radio? Disregard this post. found corrosion between the radio fuse and the fingers it clips into. A litlle 320 sandpaper and now I have power to the radio connector.
    Last edited by Mark G.; September 26, 2021, 11:34 AM. Reason: found solution to question
