C2 wiper motor - NCRS Discussion Boards
C2 wiper motor
  • Enzo C.
    • January 12, 2012
    • 536
    C2 wiper motor
    Looking for a good source to rebuild C2 original
    Wiper Motor
    Fuel sending Unit
    appreciate any feedback
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
  • Gary B.
    • February 1, 1997
    • 7068
    Re: C2 wiper motor
    Steve Hackel for wiper motor restoration (www.restorationservice.net/)
    John Wolf & Co for fuel sender restoration (www.antiqueinstrument.com/)
    Search the archives for more info, or their websites.
    Gary
    • Gary J.
      • April 1, 1980
      • 1246
      Re: C2 wiper motor
      I have heard that John Wolf had stopped doing the fuel sending units. Hope that is not the case.
      • Gary B.
        • February 1, 1997
        • 7068
        • Jim D.
          • 2885
          Re: C2 wiper motor
          Gary
          Steve has done several for me. Fast turnaround and high quality work with the correct color washer valve.
          • Mike M.
            • May 31, 1974
            • 8408
            Re: C2 wiper motor
            brian tillus at corvette specialties of md west. mike
            • Joe R.
              • July 31, 1976
              • 4552
              Re: C2 wiper motor
              Steve Hackel at Restoration Service 1 708 687-4183 is the King of the Wiper Motors!
              JR
              • Enzo C.
                • January 12, 2012
                • 536
                Enzo Colosimo
                ENZ-Z06/67
                • Enzo C.
                  • January 12, 2012
                  • 536
                  Re: C2 wiper motor
                  Yup John wolf is no longer doing sending units
                  Enzo Colosimo
                  ENZ-Z06/67
                  • Gary B.
                    • February 1, 1997
                    • 7068
                    Re: C2 wiper motor
                    Bummer. Their work was superb.
                    Gary
                    • Enzo C.
                      • January 12, 2012
                      • 536
                      Re: C2 wiper motor
                      I agree I used them a few times also
                      Enzo Colosimo
                      ENZ-Z06/67
                        • December 1, 2005
                        • 199
                        Re: C2 wiper motor
                        Enzo,
                        I sent two fuel sender units to Bob's Speedometer in Michigan for restoration. Unfortunately, it took sending them back three times to get them working correctly. I'm not convinced that he bench tested them until the very last time. I sent him the John Hinckley article on bench testing and he finally got it right. I dealt with the owner (Bruce) and he was reasonable to deal with and made it right with me, including paying for shipping both ways after the first trip. You can google their site at www.bobsspeedometer.com and phone 800-592-9673. You may want to do more research from others to get their opinion on Bob's. I thought they did a nice job for the most part. One thing that we did experience was fuel leakage at the wire terminal connections. Bob used the original gaskets (I guess you would call them that) and we had fuel dripping. We took them apart and used fuel resistant sealant which solved the problem. Now I can't recall the brand of sealant but if you need it I can get back to you. It must be fuel resistant. Hope this helps.
                        • Gary B.
                          • February 1, 1997
                          • 7068
                          Re: C2 wiper motor
                          Terry,
                          Boy, I would have thought that the use of fuel resistant sealant around the terminals, and bench testing would be standard with any fuel sender restoration. I know that John Wolf routinely used terminal sealant. Otherwise, I think the thru-terminals are destined to leak.
                          Gary
                          • Grant M.
                            • August 31, 1995
                            • 448
                            Re: C2 wiper motor
                            Recently installed an NOS fuel sending unit on a new (repro) tank. New gasket and lock ring and the unit leaked fuel around the fuel outlet tube where it was soldered/welded or press-fit to the plate. Got a new (repro) from CC and no problems. Will likely try to rebuild the original IAW an online how-to article and then see what can be done with the NOS unit.
                            Grant
                            • Ronald L.
                              • October 18, 2009
                              • 3248
                              Re: C2 wiper motor
                              Bringing this up to see if anyone has alternative C2 Fuel Sender restoration services and results, please share sources...
