Need thread spec for GM 9420261 nut - NCRS Discussion Boards
+ More Options
Posts
  • Michael V.
    • May 31, 1995
    • 77
    Re: Need thread spec for GM 9420261 nut
    I just took the rear tail housing off my super original 1969 Camaro and those nuts were what was holding the inner taillight housing to the body.
    • Gary B.
      • February 1, 1997
      • 7101
      Michael,
      Just curious. What were those nuts screwed onto? A pot metal stud that was not threaded originally? Or some sort of steel screw or bolt?
      Gary
      • Michael V.
        • May 31, 1995
        • 77
        #18
        a steel bolt.
        • Gary B.
          • February 1, 1997
          • 7101
          #19
          • James W.
            • December 1, 1990
            • 2681
            #20
            Gary,
            The Pal nuts you show in your original post are the same nuts that were on my late production '65 coupe and I plan to put them back on. I used Evaporust, Simple Green and a brass brush to clean them up. The picture is from my database of Corvette restoration photos.
            James
            • Gary B.
              • February 1, 1997
              • 7101
              #21
              • James W.
                • December 1, 1990
                • 2681
                #22
                I took Mike M's advice and used a die nut to make some treads on my new Trim Parts tail light assemblies studs to aid in threading the Pal nuts onto the new studs. Worked like a charm!
                James
                Originally posted by Gary Beaupre (28818)
                James,
                The Pal nuts are definitely the most common finding. I know of a grand total of three ‘66s, including mine, that used the uncommon Keps nuts.
                For whatever reason my original Keps nuts don’t clean up nicely with Simple Green, followed by EvapoRust. I soaked them in EvapoRust for 24 hours on two occasions, and the rust stains just don’t go away even after scrubbing with a brass bristle brush. I’m going to use steel wool or fine sand paper and then paint them to simulate gray phosphate, which I think it what they were originally. I may never use them if the risk of shearing off a lamp housing stud feels imminent, which is what another person described to me.
                Gary
                • Gary B.
                  • February 1, 1997
                  • 7101
                  #23
                  James,
                  Exactly what die nut did you use?
                  Gary
