Hi All,
I know that the title may sound very similar to many threads here however, I have not been able to find a reason for my clicking and so I have questions:
- Symptom
- turn key and starter clicks ( more than once) until I turn off the key.
- Cause
- Really not sure:
- My thoughts have been, is the motor seized? I have turned the motor over from using longer crank pulley bolts and a bar. The motor turns over from there. Is the battery bad? I checked the battery with a multi-meter and it is greater than 12v. Is it the starter switch? When the key is turned to on the stater actuates with clicking sound. Isit th starter? I replaced old starter with new yesterday. Starter works by way of testing with jumper cables on the bench and so I do not think it is starter or solenoid. When motor is connected to all pulleys and starter, the start just clicks when trying to start.
- If I can turn the motor from the crank, it is not seized right?
- The issues seems to be at the starter gear to fly wheel connection and I am stuck from there..
thanks all
Best,
Brad
- Symptom
- Cause
- Really not sure:
thanks all
Best,
Brad
