C2 Clock Bezel Replacement - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5330
    The bezel on my 63 clock separated from the clock body. I removed the clock and after inspection, I'm disappointed in how the bezel was installed. It's one small screw and some glue in the other two locations. I can re-glue it back on, this is not the original installation, or install a new bezel.
    Does anyone have instruction with pictures or a video of a bezel replacement? If it looks simple enough, I'll give it a shot.
  • Timothy B.
    • April 30, 1983
    • 5196
    Re: C2 Clock Bezel Replacement
    Harry,
    I had the same issue with my 63 clock bezel and the fix was three small screws, I don't know if they were 6-32 or 4-40 or 8-32, I was just happy I could use the original bezel.
    The clock bezel still seems to be holding fine.
    • Harry S.
      • July 31, 2002
      • 5330
      Thanks Tim, The restorer, about 18 years ago, used one screw and glue. I tried some JB weld and that held for about 60 seconds. It pulled off as soon as I installed the rear clips to hold it in place. I took it apart again and there were many holes drilled in the bezel, I imagine where small screw were attempted to be installed and failed.
      UPS now has the clock and it's on its way to be repaired.
      • Timothy B.
        • April 30, 1983
        • 5196
        You did the smartest thing Harry, the clock restoration people probably deal with this often.
        • Scott P.
          • April 30, 1992
          • 178
          Harry, I use #4x1/4 Phillips sheet metal screws, one in each of the three places that the bezel is peened to the case. I have one to do tomorrow so Ill take some pictures for you. Scott
          • Harry S.
            • July 31, 2002
            • 5330
            Great, Thanks
