69 Correct nut to attach wiper door asm re-enforcement - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 525
    From the attached image, anyone know which nut is correct for attaching the re-enforement? The lower smaller one is what I recently purchased but I removed a few of the middle ones from the car so I'm thinking the middle one is original (which I can't find reproduced ).
    Jack Ottofaro
    • 15599
    Re: 69 Correct nut to attach wiper door asm re-enforcement
    You are correct. The middle one is correct. Try Richard Fortier or David Slocowski (my spelling may be off on those names). Be sure to add the sealing gasket between that reinforcement and the fiberglass it attaches to.
    • Leif A.
      • August 31, 1997
      • 3627
      Jack,
      What size is that nut? The '63-'67 outer heater box with A/C used a nut that is very similar in appearance and may be the same.
      https://www.paragoncorvette.com/p-35...e-nut-kit.aspx
      Leif
      • Joseph A.
        • June 20, 2012
        • 136
        The correct nut is cad/zinc plated and has a rotating washer attached to it. It is the same nut used to attach the radio to the radio support bracket in U69/A2 #12 AMK sells them 8 for $4 as B-13507. In your picture it the one on the right.
          • 15599
          Joe
          I don't see the washer on the right hand nut in Jack's picture. It could be either my eyesight or the internet photo quality or it just ain't there..
          • Joseph A.
            • June 20, 2012
            • 136
            Here is the nut, as you can see the washer barely extend past the nut as in the one on the right in the supplied choices.
            • Jack O.
              • July 31, 1996
              • 525
              The lower nut in my picture is the AMK nut, a keps washer 10-24 nut. The AMK and paragon nuts are smaller diameter than what I believe is the original - the middle nut in my picture - roughly 5/16 vs. 9/16.
              Jack Ottofaro
                • 15599
                Jack
                I had to get a picture. With a lot of help from my friends and apologies to the Beatles. This is from a 1971, but I believe they were the same from 1968 until the end of the wiper door.
                My source tells me: "It's a #10-24 nut, .370 across the flats. (3/8") The integral washer is .032 thick, .670 diameter. The #10 stud is 0.90" long. GM #3759924"
                • Leif A.
                  • August 31, 1997
                  • 3627
                  Joseph and Terry,
                  I concur. AMK has them in stock.
                  Keps Nuts - Conical & External 10-24 CONI KEPS NUTS .45 D CAD. 8 pk .0002" Cadmium & Wax (KNX) 3759924 B-13507
                  Leif
                  • Jack O.
                    • July 31, 1996
                    • 525
                    Thanks so much for the effort Terry! Do you happen to know if anyone provides the "caulk" behind the re-enforcement.
                    Jack Ottofaro
                    • Jack O.
                      • July 31, 1996
                      • 525
                      Hi Leif,
                      I have these from AMK but the washer is slightly smaller diameter than the originals.
                      Jack Ottofaro
                        • 15599
                        I am not aware of a source for an exact duplicate of the sealant behind that plate, but roofing felt - the thickest you can get - would be a reasonable facsimile. A little work with a hot air gun should blend them in. You can also depend on engine heat to mold them - especially if you have a big block. I often see the gasket neatly trimmed to the retaining plate. That would not be TFP.
                        • Jack O.
                          • July 31, 1996
                          • 525
                          Thanks Terry - NM
                          Thanks Terry - NM
                          Jack Ottofaro
                            • 6941
                            Re: Thanks Terry - NM
                            Jack why not use some 3M strip chalk? It should squeeze out when you tighten like the factory stuff.
                            • Gary B.
                              • July 31, 1979
                              • 926
                              The wrap used on the upper aluminum AC line, to hold the bulb in place, is a good substitute. Cut it to the proper dimesions, square, and it will squeze out around the edges like the original. I bought a Delco roll of the stuff years ago, but it also available atmost good parts houses. And Autozone and such places are not considered :-) It's a cork impregnated material, but a touch up with a large black magic marker, makes it look much gooder.
                              The original was a solid black material, almost a butyl substance. I've not found anything that matches it yet. You might take strip caulk, lay it out in a square, roll it down into a flat square, see if it works.
                              Gary B
