62 FI Question - NCRS Discussion Boards
62 FI Question
  • E S.
    • December 29, 2008
    • 451
    62 FI Question
    Hi- Is the wire "clamp" on the balance tube at the L/H forward plenum bolt typical factory?
  • Mike E.
    • February 28, 1975
    • 5140
    Re: 62 FI Question
    Absolutely
    • E S.
      • December 29, 2008
      • 451
      Re: 62 FI Question
      Thanks-Thought so, but wasn't sure.
      • John D.
        • December 1, 1979
        • 5507
        Re: 62 FI Question
        EJ, I would have to see more of the clamp to see if it's typical Rochester Products.. Your lock washer is hiding the unique vent tube clip. Part @ 7014899. Under the washer area an original had a unique bent and configuration.
        • E S.
          • December 29, 2008
          • 451
          Re: 62 FI Question
          John-Thanks for the reply- Clamp was on this car when I bought it from the second owner in july 1997; who bought it in mar. 1964 after the original owner traded it in for a 64 365 hp coupe. The original owner was a college student at 0kla. St. Univ; and used the car to commute home to Yukon,Okla. on weekends. He ordered the car, and told me that the only issues he had with the car in the time he owned it were radio quit, radiator leak,and one broken FI drive cable.
          Second owner was a mechanic in the Air Force, who used the car as a daily driver for years, maintaining and servicing the car regularly. (Valve job and hone block and re-ring at 95 K mi.)IMG_20210907_185642774.jpgIMG_20210907_185619204.jpg
          • E S.
            • December 29, 2008
            • 451
            Re: 62 FI Question
            John-Here are better pics. of 62 vent tube clip-Do you think it is RP?
            thanks-E.J.IMG_20210909_172040448.jpgIMG_20210909_172052704.jpgIMG_20210909_172110506.jpgIMG_20210909_172148428.jpg
            • Jim L.
              • September 30, 1979
              • 1816
              Re: 62 FI Question
              There is no doubt a wire clip was installed to support the balance tube. That looks like a factory original piece.
              • Chuck B.
                • August 31, 1987
                • 122
                • John D.
                  • December 1, 1979
                  • 5507
                  Re: 62 FI Question
                  EJ, Very nice original and very rare piece. John
                  Yours is perfect also Chuck Banks. Nice
                  • E S.
                    • December 29, 2008
                    • 451
                    Re: 62 FI Question
                    John- Thanks for the info.- I am also curious about the fastening hardware for this little clamp.
                    This one had: clamp- flat washer -nut
                    Kind of an unusual situation-Did you mention lock washer?
                    Would not want to "mangle" the clamp when tightening the nut?
                    Thanks-E.J.
                    • Dan H.
                      • July 31, 1977
                      • 1369
                      Re: 62 FI Question
                      Using washers is not a great idea, I miscounted upon FI removal once, one slid down into a cylinder, had fun pulling the head to retrieve it. GM did not use any nor are they needed, very low tightening torque is required.
                      Dan
                      1964 Red FI Coupe, DUNTOV '09
                      • E S.
                        • December 29, 2008
                        • 451
                        Re: 62 FI Question
                        Dan-Thanks for your input- I was just wondering what is typical in this situation. I think I have seen this clamp on a friend's very early 63 back in the day.
                        Your 64 sounds amazing! In the late 70's, I had a red/red leather 65 FI coupe (drum brakes).What a wonderful car- Drove it Bloomington and back from central Ks. a couple times.
                        E.J.
                        • Don H.
                          • December 1, 1981
                          • 1490
                          Re: 62 FI Question
                          EJ, I highly recommend using "AN" washers on almost ALL aluminum F.I. applications - plenum to adaptor plate, adaptor plate to heads, etc. That type of washer is barely visible under the nut or bolt and helps prevent the aluminum from galling when tightened. They were not designed to be installed multiple times. If I am judging the car I will note the application of washers but NOT take any points. Good luck, Don H.
                          • E S.
                            • December 29, 2008
                            • 451
                            Re: 62 FI Question
                            Don- Makes perfect sense-Thanks
                            E.J.
                            • John D.
                              • December 1, 1979
                              • 5507
                              Re: 62 FI Question
                              No washer of any kind was used under the 8 nuts to hold the FI onto the baseplate.
                              The original nuts have a flat surface to the bottom and top of them. Sort of like a build in washer.
                              Jerry Bramlett. I know you are looking in. Please post a pic of the original nuts. Thanks, JD
