motive brake pressure bleeder 66 non power brakes - NCRS Discussion Boards
  • Robert P.
    • October 19, 2019
    • 307
    Hi, was looking thru the old threads and motives web site and i see no mention of an adapter to fit the 65/66 non power brake master cyl . am i missing something or do you take the square and make it work
    thanks Bob
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: motive brake pressure bleeder 66 non power brakes
    Been bleeding them with out all that for 50 years...
    • Mark E.
      • April 1, 1993
      • 4555
      I haven't used it but their universal round adapter should work.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Robert W.
        • June 28, 2018
        • 134
        Do "people" add brake fluid into the Motive bleeder or simply use it as a pressurization device? I have one I got specifically for a 1966 PB system and I've only used it as a pressure device. I bleed one wheel and then refill the master and go to the second caliper...
        • Leif A.
          • August 31, 1997
          • 3633
          And, this is how it's supposed to be done.
          Leif
          • Mark E.
            • April 1, 1993
            • 4555
            I believe the instructions say to put fluid in the bottle and push the fluid through its lines. I did that once and found it messy. Better to use the Motive as an air pump and keep filling the master. Easier clean up too.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Robert P.
              • October 19, 2019
              • 307
              I have come up with an idea that may work , have an old original master cyl.cover that i am going to drill a hole in and install a barb fitting that will hook up to the motive pressure bleeder. any thoughts to this idea
              Bob
                • 11644
                I always add fluid to the Motive reservoir, it works like a charm.
                For the last wheel I occasionally tip the reservoir over a bit so the intake line is now getting air instead of fluid. That minimizes air in the hose, and I've not had any issues.
                • Mark E.
                  • April 1, 1993
                  • 4555
                  Bob
                  Might work. Would it be easier to use the universal round adapter?
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
