66 427/425 voltage regulator - 1119515 cover temperature - NCRS Discussion Boards
  • John L.
    • November 30, 1997
    • 409
    Replaced the VR in my car. Took it for a ride. Checked under hood and VR cover was very very hot. Is this normal ??
  • E S.
    • December 28, 2008
    • 450
    Re: 66 427/425 voltage regulator - 1119515 cover temperature
    Hi- Checked my L72 regulator cover after an hour or more trip- I have no idea what "normal" is, but this one (pretty sure it is original to car #37xx); measured 142 degrees. (I used a quality infrared thermometer)
    Hope this helps
    E.J.
    • John L.
      • November 30, 1997
      • 409
      thank you for the response
      • John L.
        • November 30, 1997
        • 409
        Finally got to check my voltage regulaator cover temperature after about an hour driving and it was 142 degrees. I also used a quality infrared thermometer.
