C3 Caliper bolts - NCRS Discussion Boards
C3 Caliper bolts
  • Robert G.
    • April 13, 2017
    • 72
    C3 Caliper bolts
  • Russ S.
    • April 30, 1982
    • 2163
    Re: C3 Caliper bolts
    I have never seen zinc bolts on the calipers.
    • Robert G.
      • April 13, 2017
      • 72
      Hi Russ,
      thank you for replying
      best regards,
      Bob
        • 43259
        Originally posted by Robert Gallo (63502)
        Hi Russ,
        best regards,
        Bob
        Bob------
        1965-E1967 used black phosphate finished place bolts. L 1967+ used black phosphate finished conventional bolts. It's possible that much later C3 used zinc plated bolts but definitely not for late 1967-73. Usually, I believe zinc plated bolts represent replacements.
        • Ronald L.
          • October 18, 2009
          • 3248
          Joe,
          Unless there was a print - part number change, which we do know know of, then there was no zinc.
          And those that know a little metallurgy will tell you its not what you want to do, the plating process produces hydrogen embrittlement.
          When I bought them in 1980 from GM, they were the same as those that got put on the cars in the 60's.
          • Brian T.
            • September 30, 1990
            • 190
              • 43259
              Originally posted by Brian Tilles (18175)
              Joe,
              After all of these years, I learn that they are called “place” bolts.
              thank you for that knowledge!
              Brian
              Brian------
              You're welcome. By the way, place bolts are designed so that the head provides a locking function. They are still used today for some applications. I don't know why GM stopped using them when they went to the 2nd design calipers. Obviously, cost must have been part of the reason but if a locking feature was considered necessary for 1st design calipers, I don't know why it would not be equally important for 2nd design and the conventional bolts used for 2nd design were not used with a lock washer or any other locking mechanism.
              • Gary B.
                • February 1, 1997
                • 7054
                • Robert G.
                  • April 13, 2017
                  • 72
                  Thank you Brian, Ron, Joe, Russ, Gary!
