1965 Fuel Injection Radiator Support "X" Bracing - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 886
    One of the lower welds on the tabs that hold the "X" bracing is only welded on one side. Did they come that way from the factory, or should I clamp the tab down and reweld? See pictures. Thanks in advance for your responses.PXL_20210816_220846386.jpgPXL_20210816_220857279.jpgPXL_20210816_220900750.jpg
  • Mike M.
    • May 31, 1974
    • 8409
    Re: 1965 Fuel Injection Radiator Support "X" Bracing
    clamp the bracket down and re-weld it. mike mccagh
    • Stephen B.
      • April 1, 1988
      • 886
      Thanks Mike
      • Mike M.
        • May 31, 1974
        • 8409
        if u dont have access to a spot welder, i'd drill a 1/4" hole clear thru the arm of the bracket, then mig or tig the clamped bracket to the core support. u can dress the weld bead after mig'd. it'll be more of a factory appearance, rather than welding the sides of the bracket arm to the core support. mike
        • John D.
          • December 1, 1979
          • 5507
          I carried a service replacement64-65 radiator core support to Corvette Carlisle for about three years. Finally my son says Dad please give it away. So a restoration shop I do a lot of work came by and he got a nice present.
          • Stephen B.
            • April 1, 1988
            • 886
            That's wonderful John. Now you need to give me '65 fuel injection air cleaner. Preferably NOS or nice original. lolol.
