1966 Clutch rod firewall boot supplier? - NCRS Discussion Boards
  • Robert W.
    • June 28, 2018
    • 134
    Any suggestions on a "good" supplier? My current piece is <2yrs old and its already cracked! I'm thinking of LIC as I've had good luck with their parts...
  • Leif A.
    • August 31, 1997
    • 3654
    Re: 1966 Clutch rod firewall boot supplier?
    Anything rubber I would go with Doc Rebuild first and everyone else second.
    Leif
    • Mike M.
      • May 31, 1974
      • 8408
      • Domenic T.
        • January 29, 2010
        • 2452
        Every boot including shifter rotted before I could start the car. Bought another shifter boot and it was cracked when I unwraped it!
        Dom
        • David H.
          • June 30, 2001
          • 1559
          Plus 1
          Dave
          • Leif A.
            • August 31, 1997
            • 3654
            1965 Late-1967 Corvette Clutch Pushrod Firewall Boot Repro Of GM 3857543 CAVEAT EMPTOR: Late 1965 uses a molded rubber includes a steel plate molded inside the rubber with 3 screw mounting holes. Early first design 65 uses a separate steel mounting plate with 2 screw holes used to 1965 V.I.N. 11752 approximately. 1965 1966 1967
            Leif
