68 Brake Caliper Rebuild-Advice please - NCRS Discussion Boards
  • Kurt B.
    • July 31, 1996
    • 971
    Need advice please
    One of my brake calipers is leaking so time to rebuild.
    The calipers are stainless steel sleeved but have the old lip seal rubber pistons
    Should I rebuild with new lip seals or convert to the "O" rings ?
    Thank you in advance
    Kurt
  • Timothy B.
    • April 30, 1983
    • 5203
    Re: 68 Brake Caliper Rebuild-Advice please
    Kurt,
    If it was mine I would just overhaul with the Chevron lip seals that you can probably get at NAPA and just do the caliper that's leaking.
    I know others may feel different.
    • Kurt B.
      • July 31, 1996
      • 971
      I thought of that Tim but with my luck as soon as I fix one, in a month or two another will fail since I don't drive the car. It's registered and insured but I spent 10 years restoring every nut and bolt on the car inside and out and now unfortunately it is a garage queen that gets driven around the block once a year if that. I'm old so my son will get the car and maybe enjoy it.
      • Leif A.
        • August 31, 1997
        • 3657
        Kurt,
        I'm sorry, but you're not old. 74 ain't old. Age is nothing more than a number...everything else is in your head. Get that "queen" out and drive her, she needs the exercise...she'll make you feel like a kid again...PROMISE!!!
        Leif
        • Don H.
          Moderator
          • June 16, 2009
          • 2283
          I suggest O-rings if the car is seldom driven... Less likely to leak from lack of use.
          And Leif, if age is only a number, and all else is in my head, does that include the pain in my back, and the fact that I can't hear anymore and can barely see?
          • Ron G.
            • December 1, 1984
            • 866
            Kurt,
            If you are looking to have your calipers stainless steel sleeved, then I would recommend Lone Star in Texas. Ask for Brad. If you would like to use your original calipers, then note that and you will get yours's back. Their number is:
            (903) 829-8400.
            "SOLID LIFTERS MATTER"
            • Leif A.
              • August 31, 1997
              • 3657
              [QUOTE=Don Hooper (50543);899239]I suggest O-rings if the car is seldom driven... Less likely to leak from lack of use.
              And Leif, if age is only a number, and all else is in my head, does that include the pain in my back, and the fact that I can't hear anymore and can barely see?[/QUOTE]
              What the heck happened to you Don? When I last saw you, two years ago, you looked fine...walked erect, heard just fine and were judging that day, as well, if I remember correctly You coming to Frisco this year?
              Leif
              • Ed H.
                • November 19, 2015
                • 192
                Originally posted by Leif Anderson (29632)
                Kurt,
                100% I used mine to deliver a sail for repair today. An hour each way, and an on/off ramp or two where we got to give it some real exercise! Yeeha!
                • Henry J.
                  • November 1, 1999
                  • 457
                  The calipers on both my 66 and 68 were done by Lone Star with O-ring seals. The service was excellent. They remain leak-free after many years of service.
                  • Mark E.
                    • April 1, 1993
                    • 4610
                    Recently one of my SS calipers started to leak. I bought a piston and seal kit with the intention of rebuilding it, but upon teardown, I saw one of the cylinders was scratched. So I sent two calipers (bad one and opposite one) to Lone Star for rebuilding with O-rings. Reasonable price and lifetime warranty too.
                    For an additional fee, they offer their "NCRS service". The calipers are painted black (instead of grey) with the appropriate surfaces left unfinished (instead of everything painted).
                    When I asked why they don't just paint all of them black, they said black paint takes longer to dry and slows down their process.
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                    • Bill M.
                      • 1330
