65 4 speed transmission mount - NCRS Discussion Boards
  • Grant M.
    • August 31, 1995
    • 448
    When re-installing the engine/transmission after a re-build, I used a new (repro) rear transmission rubber mount instead of one that had been in the car since 1987. Didn't keep the older mount--I know, dumb! So now the 2 1/2 exhaust pipes are close to or touching the top of the cross member opening and my mechanic is suggesting bending the u-shaped bracket downward to move the pipes lower. I saw posts either here or on Corvette Forum showing photos of original versus new repro rubber mounts and the new ones were almost 1/2 inch thicker (higher), which would of course, cause the pipes to mount higher in the cross member opening. One poster suggested using a 2 inch exhaust bracket, which has a bit of a drop-down where the clamps contact the pipe, and simply widening the ben to accommodate the 2 1/2 inch pipe.
    Wondering if anyone else has encountered this and has a suggestion or if there is a suggested source for a better (proper sized) reproduction rubber mount (or if, possible the urethane mounts are the correct height)?
    Grant 26607
  • Leif A.
    • August 31, 1997
    • 3658
    Re: 65 4 speed transmission mount
    Read post #4 in this thread.
    https://www.corvetteforum.com/forums...t-fitment.html
    Leif
    • Domenic T.
      • January 29, 2010
      • 2452
      Yes I had the same problem with a LIC mount. brought the LIC mount to Auto zone and they pulled out a mount that was not as high AND for a 67 vette without side pipes. Every thing fit at half the price. If I remember LIC had 2 different mounts for the 67. I called them to let them know that there must be a mix up. The promptly told me that they do not make mistakes. I still have that WRONG mount. The correct mount put the pipes in the center.
      Dom
      • Grant M.
        • August 31, 1995
        • 448
        Thanks for the info, Leif and Dominic. Looked LICS a few minutes ago and they have a side view photo of their mount with a tape measure beside it. It appears to be close to 2 inches, much higher than stock which is closer to 1 1/2 inches, I understand. That's the fewer part inches necessary to put the pipe lower in the cross member opening. I'll reach out to Auto Zone and see what they have. Do you by any chance have their (Auto Zone's) part number for the mount you have?
        Many thanks,
        Grant 26607
        • Domenic T.
          • January 29, 2010
          • 2452
          Grant,
          They just pulled it up (parts #) and it was 7.80 at the time 4 years ago. Wow LIC did that? When I call them I ask" can I ask a question or should I just get screwed now".
          Dom
          • Leif A.
            • August 31, 1997
            • 3658
            Many thanks,
            Grant 26607
            AutoZone and O'Reilly show to have the same part number...A2378
            https://www.oreillyauto.com/detail/c...w_applications
            https://www.autozone.com/drivetrain/...78/1011204_0_0
            Leif
            • Grant M.
              • August 31, 1995
              • 448
              Thanks. Do either of you happen to know the height of the correct mount that you got from Auto Zone/O'Reilly?
              • Domenic T.
                • January 29, 2010
                • 2452
                Not Me as it's been a while and the care is 99% done, but you can always bring it back. I doubt that you would.
                Dom
