95 Indy Pace car questions - NCRS Discussion Boards
  • Winston M.
    • August 4, 2021
    • 56
    I'm a new owner of a 95 pace car convertible with 1000 miles on the clock. For judging purposes, should there
    be a roadside assistance decal on the driver's window? If so, does anybody reproduce it? Is this a point deduction? Another question I have is where
    is the sticker listing all the option codes on the car located? My floormats have C4 logos on them.....should they be plain with no
    logo, and if so is there a point deduction for incorrect floor mats, or is the car judged with the floor mats removed? I have lots of
    original paperwork but no wheel lock bag or the felcro holder for the wheel lock key and lug nut socket....is this a small deduction or am I going to get hammered? One good thing is the car has it's original tires in perfect condition....I have another set of wheels and tires for driving the car as they are too old to be safe but the original tires look brand new with no tread wear. I've checked the operation of everything and all seems OK except the rear view mirrors move in and out on both sides, but the joy stick on the driver's door panel will not move the mirrors up and down......I assume they should be able to move up and down as well as in and out.....if so any thoughts on why this should be happening on a 1000 mile car? Is there any deduction for not having the front license cover on the car but an Indy 500 logo plate instead? I've heard mention of some sort of tape that came in the driver's arm rest compartment upon delivery....I don't seem to have that....is that a deduction? Does the spare tire actually have to have air in it
    as at the age of 26 years with 60 psi in it I'm sure it would explode! I look forward to everyone's input on these questions...thank you in advance
  • Bill M.
    • 1328
    • David H.
      • June 30, 2001
      • 1544
      Re: 95 Indy Pace car questions
      Winston
      Welcome to NCRS Tech Board.
      An unmolested 1000 mile car is likely to have few deductions. As stated before, NCRS 1994-1996 Technical Information Manual & Judging Guide "TIM&JG" (available from NCRS Store) will answer most of your questions. Also get a copy of Judges Reference Manual "JRM". Your Tech Info Manual tells you What to Judge - JRM tells you How to Judge.
      I STRONGLY suggest you DO NOT make any additions or deletions to this car before you get it judged. Stickers, bags, etc will generate deductions but they will be minor.
      Texas Chapter is outstanding - consider joining as this will be a big help to you.
      TIMJG will have descriptions of floor mats etc so you can tell if someone added them vs original equipment. At this point, when reading your TIM&JG if you find stickers/decals missing or attached DO NOT remove or add them until you get a Regional judging.
      Do not change an original car to make it match a judging guide. This is NOT a cleaning contest - 4500 points in Flight Judging with only 80 of those points devoted to cleanliness. Excessive cleaning will remove crayon marks & stickers that are judged.
      Spare air pressure is not going to be checked during Flight Judging.
      Side mirrors are checked during Operations. Could be something simple like a fuse or switch - this fails when operating per your owners manual?
      Dave
      • Gary C.
        Administrator
        • October 1, 1982
        • 17771
        Winston,
        Welcome to NCRS. Check out the Texas Chapter website www.ncrstexas.org The Texas Chapter has a Regional Event October 21~23 at the Frisco Convention Center. To register go to https://www.forums.ncrs.org/register...bscription.php Would like to meet you and see you car there.
        Ditto everything Dave said. In addition to the Judging Manual, the 95 National Team Leader is Tom Barr and you can get his email from the Contacts page https://www.ncrs.org/contact/index.php
        Welcome to the BEST Corvette Club in the World. All the best,
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Brian D.
          • April 30, 1999
          • 425
          Welcome Winston!
          In my 1982 Collector spare, I have only enough air pressure to keep the tire on the rim.
          No need for the whole 60lb psi.
          Dave H. is exactly right: clean gently and don't alter one thing before having it judged.
          Do review those two NCRS manuals, utilize local chapter resources, and Tom Barr, your national Team Leader's help.
          B.D.
          • James G.
            • May 31, 1976
            • 1556
            ALL GREAT Advise. See you in October in FRISCO. One of the best shows every year. And after 50 years in California I am proud to be a Texan and member of the Texas NCRS Chapter.
            • Ed H.
              • November 1, 1999
              • 626
              Jim, they are letting us out of Ca. Look forward to our first cold one in Texas, I'm buying. YAHOO !!!!!
              • Michael M.
                Infrequent User
                • August 29, 2012
                • 21
                • Paul S.
                  • December 13, 2013
                  • 83
                  Winston, if your car has a DL5 RPO code, PM me I can help you out with a Roadside assistance decal.
                  • Winston M.
                    • August 4, 2021
                    • 56
                    Paul I will check and see if I have the DL5 code and get back to you......thank you
