Garage Door Opener Won't Work in My '67 With Engine Running - NCRS Discussion Boards
  • Brooks G.
    • December 1, 1978
    • 286
    Guys, I have something really peculiar going on with the engine running while I am in my '67 Corvette. For some unknown reason my garage door opener will not work until I either turn the engine off or get out of the car and step away somewhere between 12 to 15 feet away. I have radio suppression ignition wires and complete ignition shielding in place. It appears that I have some kind of interference blocking the garage door opener. The same opener works fine in other vehicles. Does anyone have any thoughts? Thanks in advance. Brooks Glover Jr. (2141)
  • Gary C.
    Administrator
    • October 1, 1982
    • 17930
    Re: Garage Door Opener Won't Work in My '67 With Engine Running
    Brooks,
    Interesting. Hold old is the garage door opener system?
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Mark E.
      • April 1, 1993
      • 4607
      Have you checked the flux capacitor? They're known to leak. If you need to replace one, wear lead and make sure it's NOS. If you have a BB, you may have two. Check the JG and AIM to make sure.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Brooks G.
        • December 1, 1978
        • 286
        Gary, the I installed the opener in 2014. It has been working just fine ever since except for using it in my Corvette.
        • Brooks G.
          • December 1, 1978
          • 286
          Mark, I hate to admit my ignorance but I do not know what a flux capacitor is, where it is located, or how many are in my car. I am going to try to find out. Thanks for your reply! Brooks Glover Jr. (2141)
          • Brooks G.
            • December 1, 1978
            • 286
            Guys, I forgot to mention that the wiring harness was replaced in my '67 in 2017 and has not had that much use since. Brooks Glover Jr. (2141)
            • Jim L.
              • September 30, 1979
              • 1817
              He's yanking your chain. Um, just a hunch, you never watched the Back To The Future movies, did you?
              • Gary C.
                Administrator
                • October 1, 1982
                • 17930
                Brooks,
                What's the door opener brand and model number. Have you put new batteries in the Remote and see if the problem's still there?
                Gary
                NCRS Texas Chapter
                • Keith B.
                  • September 15, 2014
                  • 1600
                  do you have any LED in the car. I know certain type of light bulbs will interfere
                  • Owen L.
                    • September 30, 1991
                    • 891
                    Is it a hand-held remote? Will it work if you hold it out the window? Won't do either opening or closing?
                    • Brooks G.
                      • December 1, 1978
                      • 286
                      Guys, the brand of garage door opener is Chamberlain, I have no LED lights in the car. To operate the opener while in the Corvette I have to either shut off the engine or get out of the car and step at least 12 to 15 feet away. The batteries are good and in another vehicle it will open the door from 100 or so feet away. Thanks for the responses! Brooks Glover Jr. (1241)
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17930
                        Brooks,
                        Replace the battery and see if that changes it.
                        Gary
                        NCRS Texas Chapter
                        • Keith B.
                          • 1600
                          Do you have all your ignition shielding in place?
                          • Brooks G.
                            • December 1, 1978
                            • 286
                            Guys, I replaced the battery a couple of weeks ago. This problem existed before that. Keith, thanks for your response. Yes, all of the ignition shielding is in place and I am using radio suppression ignition wires. I wonder about the capacitors mentioned earlier. So much now days is made in China and they might be defective. Is there any way to test capacitors? Thanks again for all who have responded. Brooks Glover Jr. (2141)
                            • Gary C.
                              Administrator
                              • October 1, 1982
                              • 17930
                              article about improving signal strength on remote garage openers https://garagedoorguide.com/top-5-wa...remote-signal/
                              NCRS Texas Chapter
