1967 Steering Column - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1591
    I am looking for a NOS or a really good reproduction UPPER shaft bearing.
    Standard or NON telescoping column.
    All leads appreciated.
    Don
  • Bill B.
    • August 1, 2016
    • 304
    Re: 1967 Steering Column
    Don,
    Have you tried your Chevy dealer? I found that my '70 column's LOWER bearing was still available at the Parts Dept. The P/N may have been superseded but it was the real deal. (had to order, but was available)
    Bill Bertelli
    Northeast and Carolinas Chapters Member
    '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
    • Ralph E.
      • February 1, 2002
      • 905
      Don,
      Contact Mike Deneple he will what you need. Not sure if you have the early or late design, but he can help.
      magic24@twcny.rr.com
      • John D.
        • June 30, 1991
        • 875
        Just looked in the catalog, it's not available from GM
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11325
          John, is the bearing actually bad, or is it just loose inside the plastic upper housing?
          Rich
          • Donald O.
            • May 31, 1990
            • 1591
            Rich
            Rich,
            As the OP of this thread, my name is Don, not John.
            Also, the upper bearing is giving me a rubbing, or rough sound. I had lubricated the bearing when I had to replace the lower column bearing, I used wheel bearing grease.
            So now since I have to replace the 67's turn signal switch, again, I would like to repair/replace both issues at the same time. This Corvette was built in early May '67 so I believe it is a LATE model column.
            DON, not John
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11325
              Sorry for the name hiccup Don. I mistakingly thought the last post was the OP.
              OK, sounds bad. I had 2 NOS upper bearings a while ago. Iirc, early late used the same upper, lowers different. I sold them along with all of my C2 parts collection to a local parts vendor a few months ago. I'd bet he still has them. Give him a call and my name so he can check. I had all of my parts catalogued so he could check the piles easier before adding to inventory.
              His name is Ian Johnson, Florida
              Tel
              Work - (352) 429-5695
              Cell - 407-468-2049
              Rich
              • Donald O.
                • May 31, 1990
                • 1591
                Tel
                Cell - 407-468-2049
                Rich
                Thanks Rich
                • Donald O.
                  • May 31, 1990
                  • 1591
                  Originally posted by Ralph Esposito (37280)
                  Don,
                  Thanks Ralphie
                  • Donald O.
                    • May 31, 1990
                    • 1591
                    Re: 1967 Steering Column - Update
                    So I finally found time, now that the summer cruise season is pretty much over, to replace the upper bearing.
                    Removing the column and the TS switch was easy, the upper bearing not as easy. the only snag was removing a split ring retainer above the bearing/housing. After that the ball bearings just fell out, both rows. The installation was easy and straight forward....until I wen to install the upper hub and secure it with the washer and nut, then the cancelling cam spring loaded contact flew apart. Terrific
                    So now when I go to order one, the parts houses all show a black plastic and brass cam for the TELE column, and a white plastic and brass for the NON TELE. Problem is the my original 67 non tele column has a BLACK plastic and brass cam. So which is correct, my original or the repop houses?
                    Also my original horn button and the repop horn button have reversed checkered flags
