Overflow Tank holes on '71 / '72 LT-1? - NCRS Discussion Boards
  • Bill B.
    • August 1, 2016
    • 305
    Just curious if the '71 / '72 LT-1's RH inner fender skirt had the 4 mounting holes factory drilled for provisional use for the mounting of an overflow tank with the aluminum radiator on most other engine options? Granted, the LT-1 did not have the overflow tank with its copper radiator.
    Bill Bertelli
    Northeast and Carolinas Chapters Member
    '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
  • Dan A.
    • February 1, 2004
    • 212
    Re: Overflow Tank holes on '71 / '72 LT-1?
    My 72 doesn’t have the holes but it does have 4 dimples where I assume the holes would be.
    • Ron G.
      • December 1, 1984
      • 866
      My 1971 LT-1 #4504 also has the dimples, but no holes.
      "SOLID LIFTERS MATTER"
      • Paul Y.
        • September 30, 1982
        • 570
        My 1971 base motor #6365 with AC does not have the overflow tank either and has the brass radiator also.
        It's a good life!
