Bulkhead connector repair - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 952
    An upper plastic lock tab broke on my bulkhead connector on my 65 Coupe. I have the Lectric Limited repair kit and a few articles describing the repair. Any other tips are welcome.
    Dave K.
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Bulkhead connector repair
    Everything you need to know:
    https://www.corvetteforum.com/forums...onnectors.html
    Take careful note of the pin removal tool in the first picture - you'll want that before starting. Take copious smartphone pics of the wire locations before starting and have a wiring diagram handy....the Doc Rebuild OOSOEZ schematics are excellent.
    As I removed each pin I CAREFULLY lifted the small tabs on each Delphi connector to ensure they "locked in" when inserted into the new housing. Don't overdo it, just lift the tabs gently a small amount. You'll get some debate on what to pack the housing with after you're done. Some say dielectric grease others say some other goo. I used dielectric and no issues in the subsequent 6 years.
    • Dave K.
      • November 1, 1999
      • 952
      Frank,
      Did you have to use any of the Delphi connector pins? If so, how did you remove the old one from the wire without cutting the wire?
      Dave K
      • Frank D.
        • December 27, 2007
        • 2703
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11334
          I used the identical procedure on a few short wires on our 63.
          My back still hurts.
          Rich
          • Frank D.
            • December 27, 2007
            • 2703
            In fairness here is what another CF member did which appears to have worked, vis a vis, pin replacement:
            https://www.corvetteforum.com/forums...-repair-2.html
            You will note my skepticism in my posts in that thread, but its hard to argue with results that have lasted 1/2 decade.
            • Dave K.
              • November 1, 1999
              • 952
              Frank,
              Does it take two people to remove the pins? One to insert the tool and the other to pull it out or is there enough room to do both yourself?
              Dave K.
              • Frank D.
                • December 27, 2007
                • 2703
                Originally posted by Dave Kitch (33108)
                Frank,
                Dave K.
                You push the tool into the firewall side of the housing at the connector until seated and you feel it "hit bottom" holding it there while tugging on the wire on the back side of the bulkhead housing and if you've properly depressed the connector tab with the tool, the wire will almost fall out. Sometimes it helps to jiggle things a bit... Once you've done a couple you'll think, "...this is no big deal".
                A one man job. Honestly, if you tried to get two people working in that area you better be VERY good pals.
                Like most jobs on these cars, the anticipation is far worse than the actual work.
                THE NUMBER ONE CONCERN is getting the right wire in the right hole in the housing; you can have 30 amps running through some of those wires and a miswiring could be a disaster. I rechecked the wiring each time after doing about 4 connectors.
                Get one of the good Coleman LED headlamps and remove the front seat, you'll be just fine.
                • Dave K.
                  • November 1, 1999
                  • 952
                  Thanks to all.
                  Dave K. 33108
                  • Dave K.
                    • November 1, 1999
                    • 952
                    Several of the connectors are being stubborn and will not come out. I moved around these connectors and to the others. Do not want to damage a connector.
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      Sometimes you need to use another part of the tool IIRC, it has both thin and thick blades to enter the housing and depress the tab - sometimes even a round part of the tool can help. As you work the tool in "moving it around slightly and making sure its seated" push forward on the wire at the rear and then tug it rearward while jiggling it. Don't forget, its just a little metal tab hanging up on some plastic in the housing; you'll get it.
                      • Dave K.
                        • November 1, 1999
                        • 952
                        Frank,
                        Thanks for the tip. Will do.
                        Dave K.
                        • Frank D.
                          • December 27, 2007
                          • 2703
                          The only way you can screw something up doing pin removal if you yank back on the wire and distort or tear off the tab - it would take a LOT of force....to wit, don't be afraid to get a little creative with the pin/tool.
                          • Oliver S.
                            • December 1, 1999
                            • 343
                            This what I did:
                            https://www.forums.ncrs.org/showthre...811#post894811
                            • Dave K.
                              • November 1, 1999
                              • 952
                              Frank,
                              I badly damaged one pin. Will need to carefully remove and replace.
                              Dave K.
