65 Coupe rear blower - NCRS Discussion Boards
  • Dave K.
    • October 31, 1999
    • 951
    with ign in either ACC or on, I have 3 heater fan speeds. With heater off, no rear blower operation. I am not getting voltage at the brown wire at the motor. Troubleshooting steps?
    DMK
  • Don H.
    • November 30, 1981
    • 1482
    Re: 65 Coupe rear blower
    The power to the coupe rear blower comes from the fan switch. When the fan is turned on it removes the power to the rear blower. The exception to that is with factory air the fan turns on low when you engage the AC but power still goes to the rear blower (assuming the fan switch is not on). I think the rear blower power is a brown wire that comes from the fan switch. Don H.
    • Dave K.
      • October 31, 1999
      • 951
      Don,
      Have all of this.
      DMK
      • James W.
        • November 30, 1990
        • 2640
        • Dave K.
          • October 31, 1999
          • 951
          James,
          Are you referring to the rear blower switch? If so, I do not have power to the rear. I now suspect the heater switch which is a relatively new reproduction switch.
          Dave K.
          • James W.
            • November 30, 1990
            • 2640
            Dave,
            No, I'm referring to the fan switch in the dash.
            I function tested the rear blower motor by running a jumper wire from the 12v power source on the fuse block to the brown power wire that runs between the rear blower motor to the back of the dash fan switch. I did this to verify that the blower motor actually ran. I then narrowed the problem down to it being the dash fan switch. Cleaning the switch contacts at the blower motor is a good idea also.
            James
            Originally posted by Dave Kitch (33108)
            James,
            Dave K.
