rear main seal - NCRS Discussion Boards
rear main seal
  • Bruce W.
    • June 30, 1997
    • 360
    rear main seal
    Hey Guys,
    Does anyone know if a 58 fuel car used a rope rear main seal. Who makes the best leak free rear main seal?
    thank you.
    Bruce
  • Jim L.
    • September 30, 1979
    • 1816
    Re: rear main seal
    Originally posted by Bruce Wilcox (29338)
    Hey Guys,
    thank you.
    Bruce
    Oh, yes! Induction system doesn't matter. In '58 the "739" block was used for all engine configurations and it most definitely uses a rope seal.
    • Jerry C.
      • November 1, 1995
      • 741
      Re: rear main seal
      Corvette Central has a replacement for this seal.
      • Bruce W.
        • June 30, 1997
        • 360
        Re: rear main seal
        Jim,
        thanks. do you know if the replacement non rope is any better?
        Bruce
        • Jim L.
          • 1816
          Re: rear main seal
          Bruce, I've heard that the neoprene replacement seal is very good but I don't have any first hand experience with it.
          Jim
          • John D.
            • June 30, 1991
            • 875
            Re: rear main seal
            Isn't there a replacement seal with an offset so it doesn't ride in the same area on the crank as the rope seal ?
            • Jim L.
              • 1816
              Re: rear main seal
              In the world of replacement rear main seals for blocks which originally came with neoprene seals, yes, the sealing lip is offset so as to not ride in the groove created by the original seal.
              Given the broad sealing surface of a rope seal, there won't be a groove and I have trouble imagining the need for a neoprene seal with an offset lip.
