1964 back-up switch bracket - NCRS Discussion Boards
  • Jack J.
    • July 31, 2000
    • 640
  • John F.
    • March 23, 2008
    • 2424
    Re: 1964 back-up switch bracket
    Did you check your AIM? Section T86 Sheet 2.00.
    • John F.
      • March 23, 2008
      • 2424
      Just found this on the CF. Hope it helps a little.
      • Jack J.
        • July 31, 2000
        • 640
        • John F.
          • March 23, 2008
          • 2424
          See the vendors parts pictures.
            • 43291
            Originally posted by Jack Jagello (34474)
            Here’s a side view of my bracket. The screw ears are bent inward, therefore the switch is angled in towards the transmission. OK? Or should I correct the bent ears if they are truly bent? On the car, it just doesn’t look right from my perspective. Jack J.
            Jack------
            The "ears" are bent. Simply bend them so that the surfaces of the ears are parallel with the rear surface. Simple and quick fix.
            • Jack J.
              • July 31, 2000
              • 640
              Jack------
