C2 (66) Front Parking Brake Cable Question - NCRS Discussion Boards
  • Larry E.
    • 1681
    Could some-one explain how to attach the cable ball to the parking brake handle on my 66. Do I have to remove the parking brake handle ? Thanks in Advance>Larry P.S. Don't have yet but will be getting Bair's Corvette #4606 front cable.
    Larry
    LT1 in a 1LE -- One of 134
  • Larry E.
    • 1681
    Re: C2 (66) Front Parking Brake Cable Question
    Anybody?? AIM is very unclear how this is done. Larry
    Larry
    • Mark M.
      • October 21, 2008
      • 340
      Larry, If I remember right, the small aluminum pin with a square block on it's top needs to be pulled out. It presses on the parking brake switch at the firewall end. It's just lightly pressed in and has splines. When it's out the handle will turn to access the hole for the ball. If I've missed something, I'll check a car later.
      • Larry E.
        • 1681
        Mark: Is the access hole right by the handle or closer to the small aluminum pin? Anything else I should know
        before I go into this project. Larry
        Larry
        • Mark M.
          • October 21, 2008
          • 340
          The hole is near the end of the shaft the handle is on. Once you pull the switch stop out, the handle will turn a little clockwise and fully expose the hole and slot for the cable. Careful pulling the aluminum stop pin as it is soft.
          • Larry E.
            • 1681
            Mark>I want to thank you very much for helping on this subject. Something tells me there is a lot of other members reading
            your advice as this is a subject that hardly ever comes up. Now to carry it a little farther>
            Once you place the cable ball in the hole and turn the handle counter clockwise I assume this action locks the ball in;correct?
            Is there anything I should know when the aluminum pin is pushed back in? Does the warning light switch have to be positioned
            in a certain way? Thanks you very much again>Larry
            Larry
            • Mark M.
              • October 21, 2008
              • 340
              With the cable in and all adjustments to parking brake shoes than cables made, there should be tension from the parking brake spring to hold all tight. And yes, when the switch pin is back in, the handle won't rotate enough to release the ball end. If all parts bolt up as designed, than as the handle turns while releasing parking brake, the stop pin will line up and depress the switch.
