1957 Windshield Side Frame Studs and Nuts - NCRS Discussion Boards
  • Joseph L.
    • July 26, 2012
    • 162
    This is for a 1957. Later C1s may have easier access. I just installed the windshield into the frame. I have my windshield assembly set onto the body and am installing the nuts onto the side frame assembly studs. The T-bolts were easy to access.
    With fingers, it is impossible to reach the frame assembly rear studs from under the dash. To remove the windshield, I got the driver side nuts unscrewed from the courtesy light opening. The passenger side is more open. I was able to reach the passenger side nuts and remove them with a combination wrench.
    Now it is time to install the nuts onto the side frame studs. I was able to reach the forward passenger side nut with my fingers. Does anyone use a device to hold the nut at the stud so that it can be twisted onto the stud? Is access through the courtesy light openings and that allows the nuts to be installed?
    Joe
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11364
    Re: 1957 Windshield Side Frame Studs and Nuts
    Joe, I use a 3/8" drive Flex-Socket through the courtesy lamp holes. Its tricky to get them started.
    And a small amount of 3M Strip caulk(dum-dum), or similar, will hold the nut to the socket so it doesn't fall off.
    Rich
    • Joseph L.
      • July 26, 2012
      • 162
      Hi Rich
      That works. I used a 1/4 drive with a universal joint. I will be getting a set of 1/4 drive flex sockets. They work well when space is crowded. I use a 9/16 flex 1/4 drive to get a couple of the intake bolts tightened on a 2X4 manifold.
      Joe
