59 dual quad Air Cleaner question - NCRS Discussion Boards
  • Tony M.
    • August 31, 2010
    • 102
    Good morning,
    I have enclosed pictures of my 1959 Dual Quad Air Cleaner. I have listed a few questions below hoping someone can help:
    • There seems to be a copper mesh on the circumference but nothing else. Is this normal?
    • Am I missing a foam on the circumference?
    • There is an insulation type material on the top of the filter. Is this normal? I notice small particles of this insulation on the bottom on my carbs????
    Tony Marra
  • Jimmy G.
    • November 1, 1979
    • 977
    Re: 59 dual quad Air Cleaner question
    Appears to be missing foam and screen that actually filters the air. Can use a AC paper filter if desired for a driver.
    • Jimmy G.
      • November 1, 1979
      • 977
      After relooking does the top and bottom half seperate?? If not it might be a 1958 Air Cleaner Assy.
      • Tony M.
        • August 31, 2010
        • 102
        Jim,
        Thanks for answering, no it does not separate. what purpose does that insulation have?
        Thanks again!
        • Jimmy G.
          • November 1, 1979
          • 977
          It apparently is a 58 style. Not sure how far into 59 that closed unit went. It is my speculation as an engineer that the material is a fire barrier in case of backfiring. I am not a C-1 expert but I have owned a 58 and still own a Duntov 60 Perhaps someone the 58 - 60 team can tell me I am full of it or correct or what the real answer is.
          • Steven B.
            • June 30, 1982
            • 4012
            It is to arrest flame in case of backfire or--!
            • Tony M.
              • August 31, 2010
              • 102
              Did some more research and found on my 58-50 Corvette Restoration CD that this is how the cleaner was supplied. No foam...wow!
              For 1958, 1959 and early 1960, the base- and two-four engine air cleaner was a one-piece enclosed or sealed unit with a shredded steel filter element. The element appears like a coarse kitchen scouring pad, similar to that in the hydraulic cam oil-fill breather cap. Because it was sealed, it was necessary to wash the entire unit in kerosene to reuse it.The open element air cleaner was introduced early during the 1960 model year and continued in use through 1962. Gone is the shredded steel and in its place is foam that is designed to be oiled prior to installation. The foam is held in place with a wavy wire spring around the perimeter. Paper elements were not used on 1958-62 carbureted Corvettes. (FI used a paper filter element.
              • Tony M.
                • August 31, 2010
                • 102
                Thanks Jim and Steven. That fire insulation cannot be healthy for the carbs since you actually see particles. Also, if kerosene was recommended for cleaning, this would soak the insulation material!!! TBD
