Shifter Reverse Problem - NCRS Discussion Boards
  • Rick G.
    Infrequent User
    • October 24, 2007
    • 13
    I have a 64 327 4 Speed. When I put it in reverse I get reverse but the shifter doesn't fully engage into the reverse position. Reverse lights not on. Linkage doesn't seem to be jammed at all. Any advice as to what I should look at appreciated.
    • 43242
    Re: Shifter Reverse Problem
    Rick------
    If you can operate in reverse, what makes you think reverse is not fully "engaged"? Is it just based on the fact that the back-up lights do not work?
      • 15696
      It's probably either the switch adjustment or a bad switch. Look at your 1964 Corvette Shop Manual Supplement.
      • Gary B.
        • February 1, 1997
        • 7038
        Rick,
        Have you gone through the shifter setup procedure using the metal alignment block?
        Gary
