C2 Proper Lubricant When R & R Distributor Tach. Cross Gear? - NCRS Discussion Boards
  • Larry E.
    • 1677
    When we R&R the distributor tachometer cross gear what would be the proper lubricant applied to it? I assume
    some of this lubricant will seep back onto the tach. cable. How much should be applied? My car is a 66 but thinking
    this question would apply to all C2 years. Thanks in advance>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Larry E.
    • 1677
    Re: C2 Proper Lubricant When R & R Distributor Tach. Cross Gear?
    Anybody?? Thanks>Larry
    Larry
    • Larry M.
      • January 1, 1992
      • 2690
      Larry:
      When I did this job last, I used Delco-Remy #1960954 grease that is specific for this job. It can be found, but is not easy to get. Many folks use Lucas "Red-n-Tacky" synthetic chassis grease in this application. You want to use a good bit on the gears, but don't overdo it.
      Larry
      • Donald H.
        • November 2, 2009
        • 2580
        I just rebuilt a tach and I use the Red and Tacky.
        Don Harris
        Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
          • 15669
          I prefer GM 1960954 Distributor and Starter motor lubricant that I also use for the upper bushing grease well. It's long out of production, so since these are "permanently" lubricated you need a long life product that is very slow to evaporate. That means a full synthetic like Mobil 1 grease.
          • Larry M.
            • January 1, 1992
            • 2690
            Larry
            • Mark E.
              • April 1, 1993
              • 4537
              Originally posted by Larry Mulder (20401)
              $49.50 plus $13.50 shipping for 12 ounces of "vintage grease"? Mobil 1 or Valvoline synthetic grease is better and only $15 per pound.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
              • Larry M.
                • January 1, 1992
                • 2690
                OP asked what to use for rebuilding his tach distributor. Collectively we gave him three or four choices/recommendations as well as sources for the "hard to find" stuff. He can now decide which path to take.
                1. DR 1960954
                2. Lucas Red-n-Tacky
                3. Mobil1 synthetic
                4. Valvoline synthetic
                Larry
                • Larry E.
                  • 1677
                  Thanks to all that gave their opinion. Price-Wise I will go with>
                  Lucas Oil Red "N" Tacky Grease, 1 Pound Tub, 16 Ounces (LUC10574) $7.99 at various places like>Amazon/Walmart/Advance Auto and more. Larry
                  Larry
