C3 Tire Size - NCRS Discussion Boards
C3 Tire Size
  • Bob H.
    • July 31, 2000
    • 827
    C3 Tire Size
    I see recommendations for 205x75x15 and also 215x70x15. Will order T/A's but what size do you think best? Wonder if the wider rub?
  • Leif A.
    • August 31, 1997
    • 3651
    Re: C3 Tire Size
    I use to run 225/70R15 on my '72. Fit without rubbing and filled the wheel well nicely.
    Leif
    • Keith W.
      • May 25, 2018
      • 202
      Re: C3 Tire Size
      • Tom M.
        • November 1, 1995
        • 87
        Re: C3 Tire Size
        215-70-15 is spelled out in the JG as close to the original F70-15.
        The 215’s have no clearance problems on my ‘69.
          • 11692
          Re: C3 Tire Size
          Note that the current TA's have significant problems with the white letters turning brown - quickly - and being difficult to clean. Even though I currently have them on 2 cars, I am reluctant to use them as replacements given this.
          • Bill B.
            • August 1, 2016
            • 305
            Re: C3 Tire Size
            I second that, Patrick! I have to use brake cleaner on the RWLs every two weeks to keep them from turning the yellowish-brown. Lots of needless work that could have been avoided if BFG did a better job in the manufacturing process ... They may end up losing a lot of business because of this issue.
            Bill Bertelli
            Northeast and Carolinas Chapters Member
            '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
            • Patrick B.
              • August 31, 1985
              • 2009
              • Bob D.
                NCRS Shipping Data Report Manager
                • April 30, 1996
                • 795
                Re: C3 Tire Size
                I have the radial T/As mounted with the white letters facing in. Put a little black shoe polish on the white letters and the problem is solved. That is just my preference. I like black walls nice and clean.
                Bob
                • Bob W.
                  • December 1, 1977
                  • 803
                  Re: C3 Tire Size
                  Bob Are you using paste or liquid polish?
                  Bob
                  • Bob D.
                    • April 30, 1996
                    • 795
                    Re: C3 Tire Size
                    Using liquid. It sometimes takes 2 coats but it works well.
                    • Bob W.
                      • December 1, 1977
                      • 803
                      Re: C3 Tire Size
                      Bob Will the color fade after some time? I was thinking about trying to make red walls.
                      • Bob D.
                        • April 30, 1996
                        • 795
                        Re: C3 Tire Size
                        It has not faded after three plus years
                        • Mark E.
                          • April 1, 1993
                          • 4607
                          Re: C3 Tire Size
                          Do you want a tire size close to the original? Or the largest/widest that will fit? Google "Tire Size Calculator" to compare dimensions of different tire sizes. I don't know what year C3 you have but for example, in 1970:
                          (ORIGINAL SIZE
                          Mark Edmondson
                          Dallas, Texas
                          Texas Chapter
                          • Bob H.
                            • July 31, 2000
                            • 827
                            Re: C3 Tire Size
                            got the 215x70's and they look good. thanks
