71 Vette: Front Stabilizer Bar Frame Attachments - NCRS Discussion Boards
  • Ray K.
    • April 30, 2005
    • 409
    Can anyone shed any light on the '71s front stab bar mounting?
    Specifically I'm looking for info on the bracket, screw assembly and nut that retain the stab bar to the frame (not the lower control arm).
    Referencing both the '71 & '72 AIMs, items #6, 7 & 8), I would like to know the following:
    - Bracket GM#391363 (Item #6): What is the finish of this bracket (black semi gloss?)
    - Screw Asm GM#3858700 (Item #7): Looking for all info (hex? w/washer type? thread? length? head marking? etc).
    - Nut GM#9417954 (Item #8): Confirm that this nut was not welded to the frame (as shown in '71 AIM) versus welded to frame (as shown in '72 AIM)
    I tried finding the info in the '70 - '72 Judging & Technical Information Guide, 6th Edition (page 266), but, maybe I missed it.
    Ray K (#43777)
    • 11698
    Re: 71 Vette: Front Stabilizer Bar Frame Attachments
    Going from memory here...
    Bracket is dip painted semigloss black. Thinned Rustoleum works great.
    Bolts are recessed head with integral washer, black phosphate.
    Nut is welded to the frame.
    • Ray K.
      • April 30, 2005
      • 409
      Pat,
      thanks for the info . . .
      Any idea what the description of screw/bot assembly is (hex? w/washer type? thread? length? head marking? etc)?
      Ray
        • 11698
        See my second line.
        You might see more in my photos, or there is a picture in the manual, just not listed in the caption.
        I'm at work so I can't get more details at the moment.
        • Gary B.
          • February 1, 1997
          • 7078
          Ray,
          Bolt/screw asm 3858700 is described in a prior posting:
          https://www.forums.ncrs.org/showthre...338#post639338
          A good way to find info on bolts, nuts, washers, etc, is to search the archives with the GM part number.
          Gary
          • Gary B.
            • July 31, 1979
            • 926
            Page #226, Figure Ch 7.10 shows the linkbolt, washers and bushing. Fig. Ch 7.9 shows the bracketbolted to the frame and the style of bolts. Page #227 describes the link and bushing. We probably need to describe the sway bar rubber bushing, bracket that bolts to the frame and the attaching bolts a little better.
            Gary B
            • Ray K.
              • April 30, 2005
              • 409
                • 11698
                Originally posted by Ray Krawczyk (43777)
                but, based on the discrepancies in this tag, I was suspect . . .
                discrepancies?
                • Ray K.
                  • April 30, 2005
                  • 409
                  • Gary B.
                    • February 1, 1997
                    • 7078
                    Ray,
                    In that old post, Tom Russo said “seems I recall that bolt to be about 1 3/4" in length.” But the conclusion from that thread is that it was between 1.375” and 1.42”. In my experience a variation of 0.040”, or even 1/16”, is not uncommon when measuring dog point bolts, especially used ones, where the pointed tip is often rusted away or broken off.
                    Gary
                    • Gary B.
                      • July 31, 1979
                      • 926
                      Not the best picture, but it's a 71, in the shop and on the lift. I've tried everyway possible to rotaate the picture, but it keeps coming out this way. Make believe your laying on the ground, on your side, looking at the car....
                      The bolt holding the sway bar bracket to the frame measures 1.45 under the flat washer to the pointed end. The bolts are long to help draw the bracket to the frame, collapsing the rubber. It's an indented hex head, with a head mark of ELH. The washer is a captive washer. I believe the bolts were either a black phosphate or a dark natural finish from heat treating.
                      The bracket is dip painted semi-gloss black.
                      The link bolt measures 5-3/4" long. The center spacer is about 1-3/4" long, with a seam running lengthwise. The bolt hex is 9/16", even though the bolt is 5/16" diameter, fine thread. The nut is also 9/16". All of the hardware was a zinc plated.
                      What am I missing???
                      Gary Bosselman
                        • 11698
                        I thought that you and I had tossed around the idea of the upper nut being silver cadmium plated instead of zinc. Even in your photo of well-aged parts, the color differs from everything else.
                        PH
                          • 15640
                          PH
                          There is a better example of original finishes on a 1971; I just don't know where it is at the moment.
                          • Ray K.
                            • April 30, 2005
                            • 409
                            • Don H.
                              Moderator
                              • June 16, 2009
                              • 2283
                              Gary Bosselman
                              [ATTACH=CONFIG]107038[/ATTACH]
                              Gary-
                              your photos post sideways due to your camera settings in your iPhone. You need to lock the auto-rotate function before you take photos.
                              You can experiment with this a little in the Test Forum. Here is a recent thread on the issue from the Help & Support Forum.
                              https://www.forums.ncrs.org/showthre...ne-rotate-pics
