front park lamps - NCRS Discussion Boards
front park lamps
  • Francais D.
    • October 8, 2016
    • 93
    front park lamps
    L have a 1969 , when i turn headlights on front park lamps go out and my blinker lights in dash stay on solid.
    • 6941
    Re: front park lamps
    Francais, take a look at the ground for the front lights. You can try and run a temporary ground to the housing.
    • Francais D.
      • October 8, 2016
      • 93
      thank you , i have located a ground to driver side radiator support and it seems good, Will look at it more tomorrow.
      • Francais D.
        • October 8, 2016
        • 93
        i have found that the grill bracket that the bulb housing bolts to, well actually speed nuts,must be grounded thru the small bolt at top of bracket into back side of bumper support. Is this correct or is the bulb housing hard wired with ground
