67 427 clutch - NCRS Discussion Boards
67 427 clutch
  • Gary S.
    • July 31, 1992
    • 1633
    67 427 clutch
    Looking for a friend, 67 427, in need of a clutch and I found this:
    https://www.forums.ncrs.org/showthre...ght=427+clutch, Joe's thread stating the Luk 04-049 is correct for all 67 big blocks so I passed this information on. However, in the back of my mind was a comment MANY years ago about tall versus short throwout bearings. Does someone have the information of the proper throw out bearing? Friends 67 desperately needs a clutch and I suggested the Luk as per the posted link.
    Gary
    • 43295
    Re: 67 427 clutch
    Gary
    Gary------
    All Corvettes except early 1955 use the short clutch release bearing.
      • April 1, 2000
      • 477
      Re: 67 427 clutch
      If memory serves me correctly, I think the Luk kits are highly recommended with the possible exception of the throw-out bearing included in the kit (has some plastic/composite materials?). I believe the recommendation is to also buy a higher quality bearing in addition to the Luk kit. You may want to have your friend check to see if this is still the case.
      • Gary S.
        • July 31, 1992
        • 1633
        Re: 67 427 clutch
        Thank you. I passed both comments on. The last time I needed a new clutch was 25+ years ago and it was for a 327.
          • 43295
          Re: 67 427 clutch
          Gary------
          1966-69 427 (except L-88 and ZL-1) clutch is the same as used on most 1969-81 small blocks. The flywheel is the same, too.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11370
            Re: 67 427 clutch
            I've used LUK on both SB(C1s & C2s) & 2 BB L71s.
            The LUK bearing uses a industrial plastic section which the fork attaches to. At first I was apprehensive about using them, but they have proven to be a acceptable and long lasting bearing. Both L71s still going, so far 8 years and 6 years with no troubles.
            Rich
            • Douglas L.
              • August 31, 2003
              • 302
              Re: 67 427 clutch
              1967ClutchThrowoutBearingSize-6-2-160001.jpg1967ClutchThrowoutBearingSize-6-2-160002.jpg
              • Gary S.
                • July 31, 1992
                • 1633
                Re: 67 427 clutch
                A little bit fuzzy but mostly readable. Thank you. I'll pass this on. I don't know if he or his mechanic have the Chassis Service Guude. I have one for a 66 (at least I think I still have) and I'll check there once back in tow.
                • Gary S.
                  • July 31, 1992
                  • 1633
                  Re: 67 427 clutch
                  Richard,
                  Thank you for the added information
                  • David M.
                    • September 30, 2004
                    • 535
                    Re: 67 427 clutch
                    The LUK RepSet is the way to go.
                    Here is my experience...
                    https://www.forums.ncrs.org/showthre...hlight=morland
