1959 Door Panel Installation Issue - NCRS Discussion Boards
  • Tony M.
    • August 31, 2010
    • 102
    I hope everyone is well!
    I am painting and changing the metal insert on my original door panels. Over the years, the mounting holes in the fiberglass doors have become useless in it's anchoring capabilities. Holes have become bigger. Does anyone have a good solution for the door side holes?
    The previous owner installed drywall plastic inserts. Anyone encounter this issue?
    Have a safe and great weekend!
    Tony
  • Arland D.
    Moderator
    • July 31, 1980
    • 426
    Re: 1959 Door Panel Installation Issue
    Al Knoch among others sells a door panel oversized hole repair kit.
    Interior Parts for Corvette, Camaro, Chevelle, Firebird, GTO, Impala, Mopar & Volkswagen.
    • Leif A.
      • August 31, 1997
      • 3642
      Tony
      Tony,
      Though that may seem a pretty lame way to address the issue, I've used that method and it actually works pretty darn well. Especially, in areas where no one is ever going to see and you're simply looking for a good solution. You might give it a try.
      Leif
      • Tony M.
        • August 31, 2010
        • 102
        Arland,
        Thanks, AN's solution looks goos assuming the revits do not add addition space behind the panel. I am assuming the little rivetted plates are metal??
        Leif, I re-examined the drywall inserts, they are holding up well!!!!
        Thanks again!
        Tony
