oil viscosity compatibility - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1364
    In changeing oil in my '67, I first added a gal jug of Rotella T 10W30. I can buy 15W40 but not 10W30 in quart size. Will there be a problem if I use the qt of 15W40 to give the 5 qt total?
  • Jimmy G.
    • November 1, 1979
    • 977
    Re: oil viscosity compatibility
    NO Will change the overall viscosity but should be no problem. Odd that Shell sells a gallon container of some and not quarts of all. I have that same issue when I change oil as well.
    • Mark E.
      • April 1, 1993
      • 4597
      I buy the gallons and just always have a partial container on the shelf. It's a bit cheaper in the long run if you have the space. But as Jimmy says, mixing viscosity isn't an issue.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Leif A.
        • August 31, 1997
        • 3642
        Why not simply run five quarts of 15w40?
        Leif
        • William F.
          • June 9, 2009
          • 1364
          Still would have to buy additional qt unless you bought 2 gal jugs. Also, maybe being OC, but 15-40 was not on recommended list in original manual but I know a lot use it since easier to find.
