1966 Corvette Factory AC Washer Bag Survey
RPO C60 Original Washer Bag
This survey is regarding original RPO C60 washer bag reinforcement rings, and whether brass reinforcement rings are observed as factory original. As you may know, the current 1966 - 6th edition Judging Guide, page 154 states washer bag reinforcements as “grommets are steel and magnetic” while the color exhibit picture on the same page M 18-3 clearly shows the reinforcement ring to be brass.
If you believe you own an original 1966 with factory RPO C60, I would appreciate your your observation as to :
- what are your original washer bag reinforcement rings - Brass or Magnetic Steel?
- what is the width measurement of the bag side to side
- What are the last 6 numbers of your VIN so we can track if there was a production change during the model year.
Thank You
Thank You
