1959 Hood Pin Issues - NCRS Discussion Boards
  • Tony M.
    • August 31, 2010
    • 102
    Gentlemen,
    This is probably not a new subject. My hood pins will not keep the hood shut. It seems the pins ridges have worn out. I saw a few members grinding large slots into the pins to engage.
    Question: What side of the hood pin engages with the latch? I am asking to determine on which side to create the notches. Since I am consulting at a machine shop a few hours a week...maybe the deeper groove ridges would have been a better solution than the notches I created without success?? Not my finest moment!
    Thanks again and have a great evening!
    Tony Marra
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11369
    Re: 1959 Hood Pin Issues
    Tony,
    Try this.... Get a large tubing cutter for up to 1/2" copper pipe. Use it to re-cut the circular grooves in the pins.
    Credits go to Tom Parsons for this idea many years ago.
    Also check alignment. Wrap some aluminum foil over your female latches. Slowly lower the hood so the tip of the pins hits the foil. Adjust as needed to get them centered in the telltale foil.
    • Tony M.
      • August 31, 2010
      • 102
      Rich,
      Great idea, I will try this morning. I will also remove one pin and figure out where it latches on to the pin. I'm not sure because the female end is angled???
      Thanks again and have a great weekend!
      Tony
      • Dan H.
        • July 31, 1977
        • 1372
        On my 59, I would slightly loosen the female mounting bolts and let the hood shut, to center the pins, then open and snug the mounting bolts.
        1964 Red FI Coupe, DUNTOV '09
        • Dan B.
          • July 13, 2011
          • 545
          The female latch is angled to create an interference fit with the pin to hold the hood closed. The issue with them is when they wear the hole wallows out and won't hold the pin. Replacements are available and should solve your problem.
          • Tony M.
            • August 31, 2010
            • 102
            Dan,
            Perfect and I will try that after I attempt the foil idea.
            Thanks for your feedback!
            A wonderful Father's day to all the dads!
            • Tony M.
              • August 31, 2010
              • 102
              Dan,
              I think that is exactly what is happening, especially on the right side!
              Thanks and have a wonderful Sunday!
