Power windows rattle when down. - NCRS Discussion Boards
  • Gerald J.
    Infrequent User
    • January 22, 2018
    • 22
    They are tight when fully up tho. Neither side is in the furry track when down. Should they be? Is there an adjustment procedure I should perform?? Tips appreciated!
    Jerry, '63 Fuelie
  • Richard S.
    • July 31, 2006
    • 187
    Re: Power windows rattle when down.
    Jerry, '63 Fuelie
    I realize this will be of little help, but I am just happy when the power windows go up and down. I do not notice any difference between the lower and upper sections of the window regarding fit however, you do need to adjust the window to accommodate the change between the convertible and removable hardtop. I remove the passenger door panel covering and give the power window motor a whack when it refuses to work, generally works the first time.
