66 C2>Need Advice of R&R Casco #63 Element - NCRS Discussion Boards
  • Larry E.
    • 1674
    Trying to R&R Casio #63 Cigarette Lighter Element. What is the trick to get the old one off? Looking at
    the N.O.S. one there seems to be a small clip of some sort in the middle. I tried gently to snap the old one off
    w/o any luck. Do not what to damage the original Knob. Car is 66 Corvette. Thanks>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Larry E.
    • 1674
    Re: 66 C2>Need Advice of R&R Casio #63 Element
    Sorry should be Casco Not Casio>Larry
    Larry
    • Harry S.
      • July 31, 2002
      • 5293
      The knob screws into the element.
      • Leif A.
        • August 31, 1997
        • 3626
        Larry,
        Not crystal clear on what you're asking. The knob simply unscrews from the element. If you're asking how to remove the element from the element retainer, I don't have that answer.
        Leif
        • Larry E.
          • 1674
          Harry>Thanks much; got it now. Never would have thought of that. Larry
          Larry
          • Jimmy G.
            • November 1, 1979
            • 976
            I have tried to replace elements in these before Never with success. Not saying it cant be done but ------
            • Larry E.
              • 1674
              Originally posted by Leif Anderson (29632)
              Larry,
              Leif>Thanks for the reply. Just R&R Element not element from the element retainer.
              All done>looks good as original one was used (Ash Stains On It) like most. Larry
              Larry
              • Bill L.
                • April 1, 1985
                • 349
                Larry:
                Apologies if you have already done this but ... I restored the original Casco element on my 67 using a straight pin and a modelers "pin vise".
                I do a lot of scale modeling as well as real cars and this item is indispensable for both.....
                I first run the point of the straight pin around the coil to clean it out.... then twist a bit of 000 steel wool on the surface to clean things up.... it turns our like new.....you can also use a bit of compressed air to get everything out of the coil....one use darkens the element coil and it looks perfect.
                Here is the modeling pin vise and the straight pin..... give it a try...it really cleans things up pretty well....just go slowly and don't force it!!
                Regards
                Bill
