C1 Door Striker Screws - NCRS Discussion Boards
  • Gary M.
    Infrequent User
    • August 31, 1994
    • 6
    Are longer door striker screws available? Std are a bit too short with two striker shim plates.
  • Dan B.
    • July 13, 2011
    • 545
    Re: C1 Door Striker Screws
    Never seen longer screws or the need for more than one shim at most on the door striker. If the gap is excessive in the rear of the door, I would suggest adjusting the door rearward to solve your problem instead of trying to compensate with shims.
