Battery Hold bolts - NCRS Discussion Boards
Battery Hold bolts
  • Jimmy J.
    • May 31, 1988
    • 304
    Battery Hold bolts
    How do you install the battery in a 1959 and keep the battery hold down bolts from falling out?
  • Don H.
    • December 1, 1981
    • 1487
    Re: Battery Hold bolts
    I install the battery first, then the "J" bolts, then top cover. It can be a challenge to get the cover on and keep the bolts from coming loose. I haven't done it for a while but don't remember it being that tough to do. You could use tape on the j part of the bolt if needed. Good luck
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      Yes...Need 4 hands.
      The J bolts keep unhooking when you try to get the cover on. A Real Pain.
      I tightly wrap some very thin Tie-Wire, spiralled around the threads of the J bolts, then thread it through the cover holes, then cover on, then put the washers & nuts over the wire down to the J bolts, remove wire while holding J bolt, thread the nuts.
      Rich
      • Joseph L.
        • July 26, 2012
        • 162
        Use a rubber band around the bolts and across the battery.
        • Leif A.
          • August 31, 1997
          • 3626
          Hold the "J" bolts to the side of the battery with pieces of duct tape. Drop the top surround on the bolts and tighten. Remove the duct tape.
          Leif
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11323
            The problem with these is getting the bolt through the cover double wall at the side. Not sure how tape would help Leif.
            Rich
            • Keith R.
              • August 31, 2001
              • 660
              I tied a string to the top of the bolts and threaded them through the cover holes and tied them off at different engine compartment points. I also taped the bolt to the side of the battery. IIRC, you can tape it low on the inboard side then remove it from under the car. In any case, it's a real PITA.
              Keith MacRae
              NCRS #36692
              New Mexico Chapter
              1960 290HP FI
              2013 427 Convertible
              Shade tree mechanic and
              B-52 pilot extraordinaire
              • David S.
                • December 1, 1982
                • 310
                I use what electricians call duct seal. Its very stiff.
                Force it around the bolts at the battery box.
                This will stand the bolt straight up.
                When done remove it from the bolt on engine side.
                Leave it on the fender side no body will se it
                Dave
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11323
                  For those curious, this is the sheild and views of the holes for the J bolts. The side that faces the engine has a long vertical.
                  • Jimmy J.
                    • May 31, 1988
                    • 304
                    Thanks to everyone. I think with all this information it will not be a problem. Jimmy
